ZitatAlles anzeigenWhat is the correct way to get the new version ?
. Simply flash ef3-menu-1.3.0.crt into SLOT0 using the (possibly older) easyprog directly from the CRT ?
. Load easyprog-1.8.0.prg from disk, and then flash ef3-menu-1.3.0.crt into SLOT0
or either way works fine ?
First you have to update the CPLD firmware via PC USB = EasyFlash jumper set to PROG. Then flash the new menu = EasyFlash jumper set to DATA. Flashing the menu also works fine via Easytransfer USB tool, or disk/sd-card as you said. Probably works with an older easyprog version too. The new menu includes Easyprog-1.8.0 then, which has a new "L" slot for flashing the FC III bin.
