Mhm, was für Features meinst du denn da? Muss zugeben das ich noch nie die Firmware aktualisiert habe. Bin ja zufrieden, es läuft problemlos. Für neue Funktionen würde ich aber darüber nachdenken.
Neues Ultimate 2+L ist im Vorverkauf auf Ultimate64.com
- marty
- Thread is Unresolved
Aber ich mag das Gelbe am meisten.
Das Gelbe vom Ei...
Sogar ich bin am Überlegen, dabei habe ich 2x U2+(Gelb, Rot), und eine 1541 Ultimate (mit Ethernet),
ist für mich unverzichtbar das Teil, genialste hardware überhaupt!
Mfg Jood
Such Dir was aus:
- Full, cycle accurate emulation of two real Commodore 1541, 1571 and 1581 diskdrives.
- Uses .D64, .D71, .D81 and .G64, .G71 files stored on USB stick
- Supports .G64 / .G71 files as well (Read/Write)
- Configurable bus IDs
- Configurable ROM
- Memory expansion
- Built-in Speaker; outputs drive and floppy sounds
- Support for USB storage devices (stick, card reader, and even HD)
- 100 Mbps Ethernet port (for use with Telnet or FTP)
- FAT/FAT32/exFAT support, with sub-directories and long filenames
- ISO9660 support with Joliet, for reading .ISO files and access external CD/DVD drives through USB
- Battery backed up Real Time Clock
- Command Interface module with UltimateDOS
- Accessible module through I/O space that allows direct commands to Ultimate-II
- Ultimate-DOS, I/O space driven direct file access to SD/USB
- Dual SID implementation
- Ultimate Audio module
- Up to 7 voices of sampled audio simultaneously
- Accessible through I/O space
- 8- or 16-bit samples
- up to 48 kHz sample rate
- Built-in SID player; plays SID files on either 'real' SID or emulated SID.
- C64 cartridge emulation, with support for many CRT files:
- Final Cartridge III
- Action Replay
- Retro Replay
- Super Snapshot
- Epyx Fastloader
- Custom Ocean / System3 carts (up to 512K)
- Easy Flash
- ... and many more
- Commodore 1750/1764 REU
- REU Compatible
- Size selectable from 128K up to 16 MB
- Can be combined with compatible cartridge roms
- Flexible freezer menu
- select, mount, create disk images, browse disk images
- create new directories, delete files
- Ultra fast DMA load of single file programs (.PRG files on USB, inside .D64 or .T64)
- Configuration screen, with resident settings
- Tape emulation, through special USB3.0 cable to tape port of C64*
- Load .TAP files to C64
- Capture tape data from C64 to .TAP file
- Capture tape data from a datasette and store it as .TAP file
- Write .TAP files back to tape, using a Commodore tape deck
Es ist natürlich Geschmackssache, jedoch gebe ich beim transparenten Gehäuse eines zu bedenken:
Man kann durch die Transparenz nur sehr schlecht die gerade aktive LED erkennen und damit den Status des Laufwerks.
Ich bin sogar so weit gegangen, dass ich mein transparentes Gehäuse im Nachhinein durch ein Blickdichtes getauscht habe und die Lichtleiter gegeineinander "lichtisoliert" habe.
Danke, aber das ist ja die Beschreibung der Ultimate 2+ bzw 2+L. Ich würde allerdings gern mal wissen, welche zusätzlichen Funktionen die Ultimate 2 im Laufe der Jahre durch Firmwareupdates bekommen hat.
Ich kann gar nicht genau sagen, was neben den offensichtlichen Hardware- Unterschieden und daher zusätzlichen Möglichkeiten bei mir alles noch nicht geht, weil ich noch gar nicht alles genutzt oder getestet habe.
Der Funktionsumfang des Moduls geht mittlerweile so weit über eine Diskettenlaufwerk- Emulation hinaus, das es eigentlich konsequent war, 1541 aus dem Namen zu streichen und es nur noch Ultimate 2+ zu nennen. Ich würde mir aber manchmal eine Ultimate Light (oder eine Neuauflage der 2er) wünschen, die sich auf das wesentliche beschränkt. Weil ich so einiges als unnötig und preistreibend empfinde (den Lautsprecher, 3(?) USB- Anschlüsse, Micro USB, das Ethernet) Aber es ist das beste Modul, was es je für den C64 gab.
Für mich das beste Modul, was es je für den C64 gab.
Man kann die Ultimate II+ so bisl vergleichen mit der ACA500 für den AMiga 500
Das ist auch so eine Eierlegende Wollmilchsau
Wobei die Ultimate, noch mehr Funktionen bietet, als die ACA500
Beide Teile sind auf jedenfall Super gut und voll ihr Geld wert
Und bei beiden stehen echte Genies hinter der Entwicklung
Es ist doch genial, das heutzutage es noch solche genialen Entwicklungen gibt, für so alte Computer, die der Rest der Welt vergessen hat
Ok, verstanden. Das kannst Du Dir im Repository von markusC64 rauspideln. Da sind alle Releases mit Dokumentation verhanden und Du kannst ab Deiner aktuellen Version durchgehen:
Danke für den Link.
Das reichte mir schon um zum Entschluss
Ich helfe doch gerne!
Habe auch kurz überlegt, aber ich will so ein Ding schon lange haben und billiger wird's nicht.
Btw.: Alle, die schon eine alte Auflage besitzen, aber mit der neuen Liebäugeln, können sich ja überlegen, ob sie die alte
zum fairen Preis an weniger begüterte Forenmitglieder abtreten, dafür haben wir ja auch einen Marktplatz hier im Forum
und mancher freut sich bestimmt, wenn er 50 Euro sparen kann. Das ist für einige Leute nämlich gar nicht so wenig Geld,
wie andere vielleicht glauben...
Sehr nette Idee von Dir
Kann sein, das ab nun die älteren wieder mehr angeboten werden
Bisher waren die Teile so gut wie gar nicht zu bekommen
Wenn eine mal auf Ebay war, dann für 300,- und mehr
Total bekloppt einige
Aber leider is das oft so
Wäre echt toll, wenn ein paar ältere hier angeboten werden evtl.
Zu eBay ist doch jeder Kommentar inzwischen überflüssig. Da kaufe ich einfach nicht, das hat überhaupt nichts mehr mit irgendeiner Realität zu tun, sorry. Leider orientieren sich einige sogar hier im Marktplatz inzwischen an dem, was da abgeht. Ich habe schon vor 25 Jahren auf dem Flohmarkt stets einen Bogen um die semiprofessionellen Händler gemacht, die ihren billig zusammengerafften Kram zu Mondpreisen angeboten haben. Ich finde, da muss man nicht mitmachen. Und bevor jetzt wieder das marktradikale Geheule losgeht, ja, das ist nur meine persönliche Meinung und ja, jeder kann im Rahmen der Legalität machen, was er möchte, aber nein, ich muss das nicht immer gut finden. Ich fände es jedenfalls wirklich super, wenn der eine oder andere sein nicht mehr benötigtes älteres Modell für einen fairen Kurs an die Community abgäbe, weil halt auch nicht jeder soviel Geld für sein Hobby übrig hat.
Aber das war jetzt schon deutlich OT, bitte nicht weiter vertiefen, war nur als Anregung gemeint, kein Diskussionsbedarf meinerseits, danke!
Find ich toll die EInstellung
Ich selbst muss zugeben, nicht immer genau zu Wissen, was einige Sachen Wert sind
Aber die Erfahrung kommt mit der zeit immer mehr
Ich selbst, werde auch mein dann nicht mehr benötigtes SD2IEC hier anbieten zu einem sehr Fairen Preis
So solls auch sein
Ich selbst hab hier schon tolle Sachen günstig bekommen und sowas freut einfach
Kann / soll man das eigentlich gleich bezahlen wenn man das vorbestellt hat oder wird man dazu aufgefordert ? Wie habt ihr das gemacht ?
Q*bert -
wie sagt ihr da im Norden - nich lang schnacken, Kopp in Nacken
... habe auch eins bestellt und anderes Gehäuse und Zubehör für mein Ultimate-Board
genau.
Ne, wenn der Versand ansteht, dann bekommst du eine Zahlungsaufforderung, d.h. jetzt bestellen und vor Versand wird gezahlt. Du kannst aber auch direkt bezahlen.
Your order (2202xx) is a pre-order. This means that an exact delivery date cannot be given yet. You do not need to make a payment at this time! You will receive an invitation to pay, once delivery is scheduled.If you prefer to make your payment in advance, you can follow the following link
Man kann auch andere Gehäuse bestellen? Habe ich gar nicht gesehen?!
genau.
Alles klar.Vielen Dank für die Information.Hier gilt einmal wieder „Wer lesen kann ist klar im Vorteil“ 😉
https://ultimate64.com/Accessories
Es ist noch nicht zu spaet!
In der Tat, solange das noch eine Vorbestellung ist, sollte es kein Problem sein, die Bestellung zu ergänzen.
Ich dachte zwar, mit einem Ultimate64 bin ich wunschlos glücklich, aber da mir der Userport doch ziemlich fehlt, habe mir jetzt ein U2+L für meinen C64-C vorbestellt.
