Hello, Guest the thread was called1.5k times and contains 32 replays
last post from T3V6 at the
Commodore - Was niemals raus kam, aber geplant war
  • Ich habe in dieser Liste "Canonical List of Commodore Products" auch den Abschnitt gesehen, in dem die Commodore-Produkte aufgelistet sind, die zwar geplant, aber nie das Licht der Welt erblickt haben. Ich will diesen Abschnitt einfach mal hier festhalten.
    Von einem tragbaren 4032-P habe ich z.B. noch nie was gelesen. 8\|
    ------------------Commodore Models Never Produced or Marketed:----------------
    Commodore TOI Series:
    TOI "The Other Intellect"
    Commodore PET Series:
    * CBM 4032-P Portable 4032 Prototype. Had 4032, 4040, and Datasette. RS
    * CBM 8033 Color 8032. (Used NEC monitor in regular monitor housing)
    Commodore HHC Series:
    CBM HHC-4 "Hand Held Computer", LCD display, 4K ram, 20K rom,
    mini-printer, 64key chicklet keyboard with numeric keypad.
    Commodore VIC Series:
    VIC-20TV Vic-20 with built in 2" TV
    * VIC-16 VIC-20 but with 16k of RAM built-in
    Commodore 64 Series:
    CBM SX-100 Predecessor of the SX-64, had B&W monitor.
    CBM DX-64 SX-64 with two drives.
    CBM 64+ C-64 with 6845 instead of VIC-II
    Commodore 264 Series:
    116 Portable Same as 116, briefcase sized
    Book 116 Same as 116, built in power supply
    * CBM 232 C16 in Plus/4 case with 32 kB RAM BZ
    * CBM 264 Prototype Plus/4 JB
    * CBM CV364 264 with keypad and speech synthesizer. BZ
    * CBM 464 C900
    Commodore LCD Series:
    CBM CLCD Commodore Portable with LCD screen. 1MHz 65C102, BASIC 3.6,
    32 kB RAM, 96 kB ROM, 80x16 text display, 480x128 graphics,
    RS-232-C, Centronics, and H-P Bar Coder Ports, Plus-4 type
    keyboard, no SID, no sprites, ML Monitor in ROM.
    CBM C64Laptop Erroneous name for CLCD.
    Commodore PC Series:
    * PC60/33 80386, German. "Gorilla"
    Commodore 128 Series:
    CBM D128 6509, VIC-II, CTRC, SID, became the C128
    CBM C128PC Preannounce name for C128.
    * CBM C128D/81 Prototype C128D (plastic) with 3.5" drive BZ
    * CBM 256 128 with 125MB HD, one button mouse, built-in 3.5" drive FD
    CBM C128DL Prototype C128 (plastic) with 3.5" drive
    Commodore P series:(CBM P128, P-500)
    * CBM P500 B128 case, 2 joystick ports, 40 column video. LA
    C900 Series: Prototype UNIX System, dropped after Amiga acquisition
    Zilog Z8000 CPU, Runs Coherent 0.7.3, UNIX 7 clone,
    Built-In Floppy, HD, IEEE-488. MFM Disk Controller, 1MB
    9600 bps, 500 units made. Came in two versions.
    * C900/lo LoRes (80*24 Text, Max 6 Serial Lines) PL
    * C900/hi HiRes (1024*800 Graphics 2 Serial Lines) SL
    * Z 8000/lo C900/lo PL
    * Z 8000/hi C900/hi SL
    Amiga Series:
    * VELVET Prototype A1000, 128kB RAM & ROM, Portia & Daphne, C= logo SE
    A300 Prototype A600
    * A690 Early name for the A570 CD-ROM.
    A800 Early name for A1200
    A900 Early name for A1200
    A300CD A 300 + CD ROM Drive (first name of CD32 unit.)
    A1000+ 2-slot AGA w/ 2mb RAM, hard drive
    A1400 AGA A1200 with 68020/25-28mhz, 4mb ram, 80 mb hd, hd 3.5in
    A3000+ 3000 with 25MHz 68040, AGA, DSP. (<100 made)
    * A3400 A4000 prototype SE
    * A3500 A3000T prototype
    * SX-500 Amiga 500 built into SX-64 case
    * CDTV-II CDTV with built in drive BZ
    * CDTV-CR Another name for CDTV-II SE
    * CD500 Another name for CDTV-II BZ
    * CDA-1 CDTV prototype, different drive, larger display
    Commodore 64DX Series: had both 64 and 65 mode. built in 1581 style drive.
    Native mode had BASIC 10.0, dual SID, 128kB and 3.54
    MHz 6502 derivative CPU with extra addressing modes.
    Also IEC, RGBI, C64 video port, 2 joystick ports,
    reset switch, and C64 cart. port.
    Could access >64kB directly.
    * C65 Commodore 64 DX Machine JB
    * C65 "CC" C65 "Classroom Computer" as above, but no drive, 1 SID,
    no IEC, no C64 video. Has DB15 RGBI, DB25 i/o. Could be
    networked with a teachers computer.
    Cartridge Series:
    * ? Shape Grabber JB
    VIC 1934 Math Teacher I
    VIC 1936 Space Vultures
    VIC 19xx Crazy Antics
    VIC 19xx Hall of the Mountain King
    VIC 19xx Frogmaster
    Drive Series:
    CBM 1010 Pre 2040 prototype?
    CBM 1020 Pre 2040 prototype?
    CBM 1030 Pre 2040 prototype?
    CBM 1541H High density 1541 drive
    CBM 1543 1541H
    CBM 1541D Double 1541
    CBM 1561 720kB single 3.5". for Commodore LCD.
    * CBM 1563 720kB single 3.5". prototype of 1581, found in C128D/81 BZ
    * CBM 1565 3.5" drive for C65, with special adaptor for that machine. BZ
    CBM 1571 II 1571 with external PS
    * CBM 1590-D-1 Single 3.5" 1.44MB, DOS 14.13, 1581 case, Serial. JV
    CBM 2041 Single 5.25" 170K, DOS1.2, Off-White, No Rel Files, IEEE-488
    * CBM 2041 Single 5.25" 170K, DOS1.2, Off-White, PET Expansion Bus
    * CBM 4040 LP Dual 5.25" 170K, Off-White, Half Height, IEEE-488
    CBM 8070 Dual 8", ????
    CBM 8250 LP Prototype, no "tower" PCBs on motherboard PT
    CBM D9062 Dual D9065.
    CBM D9065 7.5 MB Hard Drive
    * ? 35MB HD, Serial JV
    3.5" DD FD for CBM Laptop, battery powered
    CBM HD10 10MB HD, CBM Serial
    * Amiga CD1200 External CD-ROM drive for A4000, A1200
    PC Series:
    * PC-30 PC-20-II with 20MB HD PT
    * PC-70 prototype of TW486-25C PT
    PC-80-1 80386DX @ 16MHz, German.
    PC-80-2 Pentium Pro machine. (US only)
    A2088T A2088 @ 8 MHz. V20.
    * A2286/6 80286 @ 6MHz BridgeCard. PF
    A2286/10 80286 @ 10MHz BridgeCard.
    CPU Upgrade Series:
    Amiga 2630 68030 and 68882 @ 33 MHz for A2000 with 4MB RAM
    Miscellaneous Series:
    * Amiga 3091 Internal SCSI Controller for A3000.
    It exists, but is not a product. It is a nickname for the
    SCSI Controller part of the A3000 Motherboard.
    * CD32 FMV Plug-in cartridge to play Video-CD on CD32 SE
    * CD32 key keyboard in CD32 color for aux port
    * CD32 mouse mouse in CD32 color for joystick port
    * ? Remote Joystick Controller, dark metal case/white letters
    VIC-1012 Multi-Channel Controller
    VIC-1310 Light Pen
    VIC-1521 Tractor Unit, possibly for a printer?
  • Vieles schon länger bekannt auch unter dem Stichwort "The Secret Weapons of Commodore":
    https://www.floodgap.com/retrobits/ckb/secret/
    Heut fragt man sich eben, was wirklich davon für die User interressant wäre ....
    Das hier wäre evtl. Interressant:
    The 1591 aka 1590 is apparently an HD 1581
    Aber schon die 1581 kam relativ spät und hat nie den großen Erfolg und war mit 222 DM dann sogar günstiger als die 1541 (lt. Anzeige 2Fach-Computer in der HappyComputer).
  • * ? Shape Grabber JB
    Commodore Number Nabber, Shape Grabber [Vic-1941] 8k NA U 1982
    Commodore [Vic-1903] Name needed. Anyone know what it was gonna be?
    Commodore [Vic-1934] Name needed. Probably an older Bally/Midway.
    Commodore [Vic-1936] Name needed. Planned as a Commodore original?
    Commodore [Vic-1940] Name needed. Probably an older Bally/Midway.
    These four Commodore titles above seem to be
    really elusive. Some possible titles include
    Wizard of Wor, Space Vultures, Speed Type,
    and Electronic Calendar. (These are all names
    taken from the backs of original Vic20 boxes,
    but the names don't match any software title
    as yet known to have been made by Commodore.)
    I've also been told a BASIC 4.0 cart was once
    in existence; BASIC 2.0 is what is inside the
    Vic20's internal ROMs. Commodore also said in
    early 1984 that a cart called Jack Attack was
    soon coming out for the C64 and the Vic20.
    Beyond Mountain King 16k A+ R 1983
    CBS Soft. K-Razy Antiks [22107] 12k B+ C 1982
  • Im Januar 1990 kostete die 1581 222DM - die 1541-II 299DM - Anzeige 2 Fach Computer:
    in Jahr Oktober 1988 kostete die 1581 noch 277 DM und die 1541 344DM - Anzeige 2Fach Computer:
    hier mal die anderen 2Fach-ComputerAnzeigen auch mit Amiga, Atari, Schneider, PC usw:
  • Ich habe viele Sachen für die Schule auf dem Cevi gemacht, die Lehrer waren immer begeistert
    Konfuzius sagt…Hüte dich vor Männern, deren Bauch beim Lachen nicht wackelt.
    Es ist keine Schande, nichts zu wissen, wohl aber, nichts lernen zu wollen.
    Wenn ich tot bin, dann begrabt mich mit dem Gesicht nach unten! Dann kann mich die Welt mich am Arsch lecken. ** Der Joker **
  • Bin 70er , und hatte meinen Cevi mit 14. Alles habe ich damit genmacht, geschrieben, Grafiken gezeichnet usw.
  • Ein 80 Zeichen C64, gleich mit integrierter Game-Sperre :D
    sozusagen der C64, auf dem man WIRKLICH Hausaufgaben macht? :D
    Da gibt es sogar irgendwo einen Schaltplan davon. Hab wieder vergessen, wo. Der hatte einen speziellen Taktgeber (MOS 7500, WIMRE), der auch RAS und CAS erzeugen sollte. Da wurden dann der 7701/8701 draus (in abgespeckter Form).
    [EDIT]
    Da isser ja:
    http://c128.com/schematics-c64-plus-80-columns
    [/EDIT]
  • A1000+ 2-slot AGA w/ 2mb RAM, hard drive
    Ok - geil - nie von gehört. Wenn AGA schon auf dem 1000er verfügbar gewesen wäre/sich durchgesetzt hätte (inkl entsprechenden Games), wäre ich vielleicht nicht so schnell zur DOSe gewechselt 8)
    Was habt ihr denn für die Schule so gemacht? Als ich in der Schule war, da waren Computer kein Thema, aber vielleicht seid ihr auch etwas jünger, bin 68er.
    Ich bin sogar älter, und bei uns in der Schule war Computer ein großes Thema. Davids MM in der Pause im Computerraum auf dem Schul-C64 daddeln, Software kopieren, Informatikunterricht (in der Reihenfolge :D)
    Siehe auch
    Wie kam die erste Software auf euren C64?
