ah thax a lot ! got it !
Hallo Besucher, der Thread wurde 222k mal aufgerufen und enthält 495 Antworten
letzter Beitrag von GenerationCBM am
Games in D81 format for SD2IEC device
- CommFor
- Erledigt
Does anyone have a d81 copy of Maniac Mansion by chance? I can't seem to find one anywhere and I dont yet know how to make them.
Look, for example, here
Thank you but that copy doesn't work with a 1581 disk drive unfortunately
Possible. I thought you wanna use it on a SD2IEC, that's the name of the thread.
Addendum some minutes later:
Just found out, that this version also don't work on SD2IEC by the way, but i have a d64 version which does work on it. But sadly no d81 version for 1581.
Err, I'm sorry to say that the. d81 file of maniac mansion, mentioned above DOES work. However, it is the version to be written on the easyflash.
After flashing the EF(³), it works fine!
Stefan
Yes, it works when using this d81 for writing the game to the Easyflash, but "Sinistradian" searched for a d81 which works directly on a 1581-floppy and this don't work. And on the SD2IEC it also don't work and sadly the working d64 version (2 disk-images) can not be copied on a d81 easily, because the files on the d64-images, especially disk-2, can not be listed. Needs alot work, to produce a d81 from this, which will then work on SD2IEC's, i guess.
Yeah sorry guys. I guess I should have been more clear. I have a working d64 version of this game for both 1541 floppy disk and SD2IEC but I was hoping to have a d81 version that works with BOTH SD2IEC and a 1581 floppy disk. Sorry. Does anyone know how to make this game work so that both disks are on 1 single 3.5' floppy and works in a 1581 disk drive?
On the other hand, how does one made an EasyFlash version without being able to copy all files?
This work was probably already done!?
Stefan
Stefan
You may ask enthusi
Not having the time to read the complete thread... Has anyone ever collected all the D81 images hidden in all threads and consolidated/uploaded them somewhere?
There is a real treasure here for 1581 fans (like me
) but it seems it takes much time to dig it out...
If it's not existing, I guess I have to click through the whole 16 pages...
Bugreport aus dem Zitronen Forum für Pool of Radiance:
ZitatI tried downloading Pool of Radiance patched for the GEORam cartridge from the CSDB website. When I watch the demo battle scene, the battle players are invisible. The battle takes place, but you can't see what is attacking what. I tried the game on two different computers, one with 2 Mb and another with 4 Mb of GEORam.
I guess it is only a beta release awaiting bug reports (released in 2019). I can't report the bug on CSDB, so I'm reporting it here.
Has anyone else tried this release? Does it work otherwise? -
Danke. Da werde ich fühstens am Wochenenden beigehen.
Anybody know whether there exists a SD2IEC compatible image of Lotus Esprit Turbo Challenge?
Try this. I just removedthe fastloader. Maybe it will work.
Please turn the SID-Emulation to ReSID or the game won't work.
Here an another Version from me. Ist a D81-Image
Has anyone else tried this release? Does it work otherwise?So, auch mal überprüft. So wie es ausschaut, habe ich eine defekte Version erwischt. Bei einigen Dateien stimmt die Größe nicht. Ich werde das fixen, sobald ich Interesse verspüre, mich mit über 540 Dateien anzulegen.
Thanks for your reply. Unfortunately, this version keeps reloading the same circuit over and over.
The other version which you posted, the one without the fastloader, I can't get my SD2IEC to read the image properly. This has never happened to me before. I wonder if other members had better luck.
