WinUAE 3.2.0 (11.11.2015)
Major updates:
- 64-bit compatible 680x0 JIT.
- 64-bit compatible PPC emulation.
- PCI bridgeboards.
- Commodore PC/AT bridgeboards.
- A2410 RTG Zorro II board
- DCTV video port graphics adapter (Partially)
- Genlock "emulation", including transparency and ECS genlock features.
- Directory harddrive and hardfile KS 1.2 and older full autoboot support.
New emulated expansion hardware:
Accelerator boards:
- DKB Wildfire
HD controllers:
- 3-State Apollo 500/2000
- A2090 previously missing ST-506 support
- Elaborate Bytes A.L.F.
- Kupke Golem Fast SCSI/IDE
- Mainhattan Data Paradox SCSI
- Multi Evolution 500/2000
- OMTI-Adapter
- Spirit Technology HDA-506
- Tecmar T-Card/T-Disk
- Vortex System 2000
- Xebec 9720H
Commodore x86 bridgeboards:
- A1060 (A1000 Sidecar)
- A2088
- A2088T
- A2286
- A2386SX
x86 bridgeboard expansion devices:
- AT IDE HD controller (A2286 and A2386SX)
- XTIDE Universal BIOS compatible IDE HD controller.
- ISA VGA display card (Cirrus Logic GD542x based)
PCI bridgeboards:
- G-REX
- Mediator 1200/4000
- Prometheus
PCI bridgeboard compatible PCI cards:
- FM801 sound card
- ES1370 (SB128) sound card
- RTL8029 network card
Notes:
- SSE2 capable CPU is now required.
Other Updates:
- CD and sound card emulation audio output quality improved.
- 68020/030 prefetch emulation improved.
- High DPI display support improved.
- AGA subpixel scrolling emulated.
- Support shortcut paths (.lnk) in command line.
- More undocumented chipset features supported.
- Right control = right Windows key option.
- Memory accesses only -cycle-exact mode.
- UAE devices (uaeserial etc) are compatible with KS 1.2 and older.
- Improved compatibility with very old A500 config files.
Bug fixes:
- WinPCap network mode didn't detect any devices.
- 68030 data cache emulation fixes.
- Custom to/from RTG mode switch didn't check for filter changes.
- JIT on/off on the fly change (outside of GUI) was unreliable.
- Keyboard layout changed (B/C only) during device re-enumeration.
- D3D9 non-shader mode forgot scanline texture when switching modes.
- Audio wave recording created huge broken wave files.
- It was not possible to select HDF PCMCIA SRAM and IDE options.
- Flash ROM and RTC file dialogs didn't allow creation of new files.
