EasyFlash 3 - Verify error at 00:00:0:04000
There are 7 replies in this Thread which has previously been viewed 2,571 times. The latest Post (October 13, 2021 at 2:30 PM) was by Claus.
  • Hello everyone and many thanks in advance to those who can give me a possible resolution to my problem with EasyFlash 3.
    When I want to put the initial .crt file I get the following error
    I give stop and I see that I am in state
    then I verify if I record something in said position with the Hex Viewer tool and I see that I record the data,
    I can not find the logic of that error . Does someone come up with something similar? Someone knows what the logic of "Verify error at"
    is
    Thank you very much to everyone who can give me some possible solution
  • As nobody seems to answer, I am entering speculation mode ^^ . I guess the verify comes from checking byte 0x0400 = the 1024th byte after writing it to the cartridge and finding out that instead of the written value of $86 it finds a value of $FF. So there is an issue with the memory on your EasyFlash, or potentially an issue with the wiring. In order to see the issue in the Hex Viewer, you would need to scroll down to position 0400, which is further down from your screen shot. You should see an FF there I guess, which is not what was written.
    Now how this can be fixed I have absolutely no clue and one of the hardware Gurus needs to chime in... :nixwiss:
    Please login to see this link. - Please login to see this link.
  • Please login to see this link. Thank you very much for your response, I commented that it is true that this memory position is in FF, but there would have to record the next block (that result gives in the verification)
    Please login to see this link. Could you solve it? if you could how I solve it? from now I appreciate your response
  • These kind of errors appeared on my EasyFlash 3 because of faulty a "256-kbit (32 Kx8 3.3 V 55 ns SRAM - sTSOP-28" chip.
    Would a faulty SRAM be detected by the RAM Test, available in EasyProg?
    Mein GitHub: Please login to see this link.
    EasyFlash3 DIY: Please login to see this link.
    Mein Discogs: Please login to see this link.
  • Hallo, ich wollte denen, die an diesem Beitrag mitgewirkt haben, den ich vor mehr als 2 Jahren erstellt habe, mitteilen, dass ich, nachdem ich einige Dinge auf gesundheitlicher Ebene durchgemacht habe, nicht wegen Covid-19, sondern davor war, und eine sehr große Quarantäne in meinem Land (Argentinien) Ich konnte ein gutes Ende erreichen.
    Ich sage Ihnen, dass ich viel, viel, viel gemacht habe, wie zum Beispiel Flash und RAM entlöten und mehr als dreimal neu löten, reinigen und löten, alle Spuren 1 bis 1 durchgehen usw. usw. Ich beschloss, mit dem Austausch von Komponenten zu beginnen, ein weiterer großer Nachteil ist, dass sie in Argentinien nicht verfügbar sind, daher musste ich sie auf andere Weise besorgen und das hat auch Zeit gedauert, das erste, was ich bekam, war der Flash (MX29LV640EBTI-70G) und zum Glück dort endete das Problem am vergangenen Wochenende.
    Natürlich vielen Dank an alle
    Hier ist das Bild meines funktionierenden EasyFlash3.
  • Vielen Dank für das Feedback! Ich freue mich, dass das EasyFlash jetzt funktioniert :thumbup:. Und natürlich freue ich mich auch, dass Du die gesundheitlichen Probleme überwinden konntest.
