Hi all,
I'm back to this topic ... i have tested EasyFlash3 sized case for Unicart64 and it fits !
So, it is practical to purchase somewhere the empty case and Unicart64 board will be safe.
Important: I DO NOT recommend to touch buttons by fingers, please USE PLASTIC pens etc.
The possible CASE for Unicart64 board:
Here you can see my test.
closed, inside C64 expansions port
Of course, the holes DO NOT fit for buttons and SD card, and also the EDGE connector is a little bit higher, but it is still USABLE !
Creating "homemade" holes and buttons:
This is my tip how to create "homemade" case from standart EasyFlash3 case .
I have used not suitable case for it, but I believe the same can be made for EF3 case.
More critical part is to drill the 3 holes in right position ... maybe you are able to do it better .
The buttons can be made from diodes by cutting their heads ... learned from old homemade polish BLACKBOX cartridge from 80s .
The size of holes must be the same like size of diode head. You can see that bottom of the diode is a bit larger ... so it is possible to put it there only from inner side.
And the final result here ... please don't smile too much
The hole for SD card is really ugly, but I believe you will do it better.
Now, you can push buttons on the board safe !!!
