Hallo Besucher, der Thread wurde 804 mal aufgerufen und enthält 2 Antworten
letzter Beitrag von MIRKOSOFT am
Extension of BASIC & SYNTAX ERROR
  • Hi!
    I'm working on own extension of BASIC7.
    I have finished some commands, but...
    If command has no parameter everytime all is ok.
    When I add any parameter, e.g.:
    $10 (directory drive #10)
    ... code works ok, but final output after directory is ?SYNTAX ERROR.
    As I know on C64 is possible to disable output errors:
    POKE768,139 - enables
    POKE768,64 - disables...
    Also I want to ask how to include to code that RUN/STOP stops listing etc..
    On C64 it works with implementing JSR $A82C
    I'm grateful for every help.
    Miro
  • As I know on C64 is possible to disable output errors:
    It is not a solution to disable error messages. There is a reason cause an error appears. After reading 10 next Char should be "\0" (char 0) for line end. If not, maybe you have a too less CHRGET or to many CHRGET ...
    To enable BREAK you simply can call Sys procedure or you can Call Sys proc QryBreak and abort if <Break> pressed.
  • ...but I solved problem with errors that if is my command used (I manage my own errors), I rerouted vector on $0300 to $4db7.
    If is used standard, or no my command, I reroute this vector back to default.
    So are managed errors correctly.
    What I'm searching for is routine which enables to stop ML program with key RUN/STOP.
    C64 has this routine, as I wrote...
    But also thanks - if I didn't manage own errors, solution is impossible...
    Miro
