When I run Mega Assembler with Xemu, I get the message "syntax error at 250" Listed: "250 DA=$1600: REM Default Address for Assembly. I have also copied the Megaasm.d81 files to the SD Xemu disk using DirMaster.
Hallo Besucher, der Thread wurde 2,7k mal aufgerufen und enthält 7 Antworten
letzter Beitrag von sundance am
Mega Assembler syntax error at 250
- Problem!
- KSimcomal
- Erledigt
Just an idea, what is your ROM version you're using?
Hi there, the screen show Basic 10.0 v0.9B.911001. It also has a yellow border. Just starting with Mega65 on Zemu. Just ordered the Mega65 last week.
You should use the latest Mega65 ROM.
Actual version is 920364.
I think that solves your problem.
You can find a diff file on mega65.org in the ‚Software - File Host‘
Then you need the 910828 ROM from C65. The 910001 does not work.
Then you need M65Connect for your Windows/Mac OS/Linux to apply the diff file to the 910828 ROM.
(all can be found on mega65.org)!
The problem that you're using original C65 ROM. It does not know the hex number feature $1600 in line 250 (among many-many other things). This syntax is a MEGA65 BASIC (BASIC65) extension so you need that ROM to work.
Is the problem simply that KS is using the wrong ROM version, as LGB-Z has stated?
Yes
Thanks SkulleateR
I'd give a "like" to your post, if it were possible - but this temperamental forum says I'm not authorised to do so
