ManuFerHi hat alternative Menüs für den MIST veröffentlicht die NES oder SMS "Hintergrundanimationen" ermöglichen.
Die Bedienung ist die gleiche wie bei dem altem Auswahl Menü.
QuoteDisplay MoreThere are 2 versions of alternative core, the one that can put roms of Sega Master System (SMS) in the background,
and the one that does it with roms of Nintendo Entertainment System (NES).
It is normal to put a demo and not a game as rom of the core menu, and not large, or the menu core will take a long time to start.
Advantages of these cores: They are more spectacular visually, being able to put a background demo
The new core menus go to 60hz (they are compatible with all monitors), but if you want 50hz in PAL,
you just have to start the NES or SMS core, configure it in PAL, save the configuration,
and copy the sms.cfg file or nes.cfg with menu.cfg name. The video signal of these cores is stronger,
which allows the video output to be output at the same time by the RGB and the VGA on Mistica FPGA16.
This with the traditional core was not achieved because it has a fairly weak signal,
and when connecting the two outputs at the same time the signal was lost.
Ich war so frei und hab ein einfaches NES Fire Demo mal fix angepasst für den NES Menü Core.
Im Angang die Cores:
