I'm trying to run Shadow of the Beast 1 on the Amiga (AGA) core. Is there a setting that make it work? I've tried several images, several settings (OCS, ECS, AGA), but each time it crashes when I go left into the forest, after a while. The same disk images work in the UAE emulator.
Hallo Besucher, der Thread wurde 5,6k mal aufgerufen und enthält 3 Antworten
letzter Beitrag von Negan am
I run left into the forest after a while comes a tree. Now i am inside the tree. There seems to work everything.
I have tried the registered WHDLOAD Version (V2.1 of the game) on AGA Core.
I have only tried the floppy version. I haven't set up at the moment a good hard drive desktop..
To setup a harddrive environment is quiet easy. You need to set upa HDF in WinUAE and install Workbench 3.1, BetterWB and if you want a bit eyecandy youcan install MagicWB and MagicMenu. WHDLOAD works fine on the MiST.
