Hallo Besucher, der Thread wurde 459 mal aufgerufen und enthält 0 Antworten
letzter Beitrag von mrnop am
Dreamload Menu Creator (DMC)
  • This is a front end for the Dreamload fast load system.
    A summary of what it does is, it prepares a fast load menu for a disk containing large files (up to 197 blocks).
    What separates this from other file loaders is that it's designed to be a track and sector loader. It will take your files, remove them from the directory and write a fastloader to the disk. The only file left on the disk will be the fastloader and the game data will be on the sectors.
    Think of it like the old Electronic Art games.
    This program is designed to work only with Dreamload which is included on the disk. There's a documentation file and you don't need to know machine language to use this.
    This was only made for fun Smile If you use it or never use it, it provided several nights of fun. As Dreamload supports track loading, I felt front end support would be useful.
    https://tinyurl.com/dmcload
    Refer to the demo disk for the final product. Source code is provided.
