What kind of extra port slots would you like to have on the MEGA65 ?
Es gibt 24 Antworten in diesem Thema, welches 6.806 mal aufgerufen wurde. Der letzte Beitrag (21. Mai 2020 um 17:53) ist von Freddy.
  • What kind of extra ports would you prefer on the MEGA65 ? 34
    1. 2 Break-out ports - 1 in the size of the Userport, 1 in the size of the tape-port (11) 32%
    2. 2 slots - 1 in the size of the Userport, 1 in the size of the tape-port (10) 29%
    3. choplifter (3) 9%
    4. 3rd and 4th joystick port (1) 3%
    5. No extra ports, to keep the case as original as possible (2) 6%
    6. 2 expensionport like slots (full bus controll) (2) 6%
    7. 3 slots - User Port, Tape Port, IEEE-488 (5) 15%
    Hello,
    we are finishing the case design for the MEGA65 and we wanted to ask you, what you would prefer ?
    2 Break-out ports (If not used, the case will be closed but they could be broken out, if someone wants to implement something to the MEGA65).
    2 Normal slots, the ports are plain open, might be a little cheaper in the production.
    The slot sizes will be standard Userport (15 x 76mm) and standard Tapeport (15 x 51mm) slots
    Bitte melde dich an, um diesen Link zu sehen. <- here you can find all MEGA65 related files, games, etc.
    Bitte melde dich an, um diesen Link zu sehen. <- MEGA65 main Homepage. links to all important MEGA65 sites (links on top of the page to Files, Forum, GitHub, Manual,etc.)
    Bitte melde dich an, um diesen Link zu sehen. <-Pauls Blog - constant updates about current tasks, project status, etc.
    Bitte melde dich an, um diesen Link zu sehen.,Bitte melde dich an, um diesen Link zu sehen. <- All Open-Source information regarding MEGA65. Found Bugs ? create an issue there please!
    Bitte melde dich an, um diesen Link zu sehen. <- Join for live chat support and more --- The Future is 8-bit !!!
  • Just to be clear... there's no chance for "recloseable" slots, because that would be too expensive, right?
    Then I think I would prefer the "normal slots", just to keep all cases the same and not having expensive "Ebay cases" later with the break-out ports still intact and cheap "already destroyed" cases with the ports broken out. - How long will the vote be open?
  • I'd prefer the open ports too. We have many options for 3d printed slot doors which could be used to close them, if wanted.
  • If somebody may design the backdoors and publish it at thingiverse.com might be helpful.
    ___________________________________________________________________________
    Ultimate64, TAPunio, SD2IEC, ZX Spectrum 48k, 1581 Replik, C64 Laptop, C64 MK II, C116, SX64,
    MiSTer FPGA, TI99/4A mit PEB, Atari 800 XL, Anycubic I3 Mega, Mega65, C64 Modular, Uniprom64
  • I would like to vote for the following:
    No matter which solution, as long as there are ports. I think it's okay if they are break-outable, it's also okay if they are already open. And it's also okay if there are 3 instead of two (though I have no idea what the IEEE-488 is for). But don't go for the "no ports" solution. I also don't understand the "to keep it as original as possible" reasoning, because it's different from the original C65 anyway already.
    The Bitte melde dich an, um diesen Link zu sehen. expansion which I'm hoping for is an additional S-Video out...
    - neue Spiele für den C64 -
  • How long will the vote be open?
    probably a week or two, depending on, when we have the meeting with Hintsteiner.
    We're not sure about the stability point of view. we want to keep the case as sturdy and strong as possible, we also believe two ports should be absolutely sufficent.
    Bitte melde dich an, um diesen Link zu sehen. is more information. but this bus is not on our scope at all, we could check the dimensions of that port and maybe increase the size of the Userport slot, so the IEEE-488 could fit as well.
  • adtbm - IMHO such User Port + IEEE-488 slot would be far too wide, it would have weakened the case. Besides, covering just one unused part of the opening probably wouldn't be practical.
    My suggestion (after reading the wishes above): put the User Port and Tape Port, see how much space is left at the back of the case. If above, lets say, 8cm, add a 3rd opening, without any specific bus/socket in mind - maybe for additional joystick ports, maybe for S-Video, maybe for IEEE-488, maybe for MIDI, maybe for something else not yet foreseen by anybody. Otherwise - future extensions can always go the Ultimate64 way: internal User Port, original User Port hole reused for other purposes.
  • Is the "weakening" part really an issue? The C64C case and A1200 case have ports from left to right too. Shouldn't those cases be "weak" then as well?
  • There must be a tape port (datasette), whether this port is a slot or breakout port, because we all have Commodore 64 software on tape that we want to load and save to modern fast media.
    I have a lot of turbo saved software on tapes from my teenage years that I need to load.
    Why not using a C64 with SD2IEC (or something else) for this task?
  • I think most important, or even crittical for the success, would be to have a Ethernet-Port-Connection.
    This is included :wink:
  • I would like to prefer a midi port in/out ( could be a mini hosiden like the yamaha reface synth series or micro din female port).
    It would be also great as an arcade gamer to have joystickports with more than one firebutton. so three is minimum.
    dont need to be parallel port pins, serial protocol aka ps1 controller or NES is enough...
    why everybody here speaks english in this german forum btw.
    A SD Card slot i assume will be there for saving and loading stuff ?
  • why everybody here speaks english in this german forum btw.
    because this part of the forum is the official MEGA65 forum and thus both english and german are official languages here
