Kung Fu Flash Cartridge
Es gibt 2.242 Antworten in diesem Thema, welches 511.109 mal aufgerufen wurde. Der letzte Beitrag (7. September 2025 um 20:31) ist von Step64.
  • Hi, sorry, but how to get access to wolke ?
    be a part of the community and after meaningful 30 post you are granted to visit the wolke ;)
    Ärger dich nicht, wenn dir ein Vogel auf den Kopf kackt. Freue dich, dass Elefanten nicht fliegen können.
    You'll need to have Forum64 membership for at least (I think) a month and a posting count of 30 without spamming. Then access to Forum64 Wolke will be activated manually for you.
    Edit: Starquake went on Warp 9... ^^
  • If you have many 8-bit computers, and you're dreaming to have one modern storage device you can attach to them all, there's solution - BackBit Pro cartridge supports 15 systems so far!
    Here's YouTube movie showing how it works on 12 of them:
    Each system has appropriate adapter which stays inside system and BackBit Pro cartridge is attached on top of them.
    That way cartridge ports are saved too, because there's no need to pull adapters out of systems.
    Look how easy BackBit Pro navigation is done here!
    All games are sorted automatically in alphabetical order, and it's very easy to find game you want.
    For example, if you're looking for Turrican, you just need to press T on keyboard, and it will automatically go to section where games started with T.
    Than just press U, and it will go to games that starts with Tu.. If you press TUR, it will select Turrican automatically ;)
    One of examples is at 01:57.
    BackBit cartridge has this from day 1 in BB firmware, it also uses just cartridge port (like KFF), so it's definitely doable in KFF firmware!
    I think this is major thing to be done.
  • wow this looks amazing!
  • A Bitte melde dich an, um diesen Link zu sehen. has been released which improves the disk emulation. This will allow some of the 116 games mentioned by CommFor to work, but not all.
    The firmware now also allows the search text editor to be controlled by a joystick, which is useful for the C64GS
    amazing work. thanks Bitte melde dich an, um diesen Link zu sehen. . If I only had a remote reset option available, I would never have to get up off the couch
  • About the download section:
    This Wolke system thing is quite confusing. At least for people that are not using it often (I used last time sometime year ago). I had to search through forum to find about this mystical creature, and then when I finally found a thread about it, the instruction were really hazy. I also paddle through this thread about it and got the "Paragraph II" tip. I got through, and now I can use the search engine. It gives me search results, but I cannot do anything. Can't click anything, can't download a thing.
    And yes knowners gonna know, and I understand the usage restrictions (for new users), but things could be a little bit more clear and user-friendly, without unnecessary mystification. It wouldn’t hurt anyone, wouldn’t it. Thank you! :)
    And back to the main topic:
    AGAIN amazing work kim_jorgensen and CommFor! Thank you very much! I really enjoy that my favourite C64 peripheral is getting better and better. :)
    The Search Engine for the "Wolke" is just a search engine nothing more or less, it tells you, in wich folder on the real Wolke you will find the things you're searching for.
  • Ahh! Got it know. Didn't know that they were two different beasts. ;)
  • È stato rilasciato un Bitte melde dich an, um diesen Link zu sehen.Ciò consentirà ad alcuni dei 116 giochi menzionati da CommFor di funzionare, ma non tutti.
    Il firmware ora consente anche di controllare l'editor di testo di ricerca tramite un joystick, utile per il C64GS
    Thank you for your support!
    Some?
    Out of 116 that didn't work before with firmware 1.39, with new firmware 1.40 only 10 still don't work!
    Marvellous job, Kim :thumbup:
    Just sent you list of non-working ones in private.
  • By the way, I was updating the Cartridge.
    Just testing what I found on the SD card.
    When I selected run n' gun, it does not start.
    I'm sure, I'm doing something wrong.
    BadMoon Rising for example works however.
    Is there a trick?
    Stefan
