Bei tme.eu
10118194-0001LF/C die Bestellnummer für die MicroUSB Buchse.
MCC-SDMICRO/3 die Bestellnummer für den SD Slot.
STM32F405RGT6 die Bestellnummer für den STM Controller
letzter Beitrag von kim_jorgensen am
Bei tme.eu
Hi,
I tried to build a flash Kung-Fu without success (trash) I can't solder the STM32 correctly, I have bridges between pins that I can't remove, which solder solution is used ?
You have to use much cheap china amtech flux. With that it should be not a big problem to solder.
that's what I use, put too much on the top of the pins, make the solder go up and create bridges between 2 pins, which is very hard to remove
Wäre es eigentlich nicht möglich, das PCB-Layout so zu ändern, dass man dort einen Standard-Quarz (8,0000-HC49U-S) einlöten kann oder zumindest eine bessere SMD-Variante (8,0000-HC49-SMD) die nicht so selten ist?
ich hatte auch den falschen Quarz bestellt und diesen eingelötet. Man muss allerdings die Beinchen umbiegen und die halten nicht viel aus:
Well, it still takes some practice, to be honest. But katarakt is right, use LOTS of flux. General rule of thumb is: if you are having problems soldering SMD components, you are using not enough flux.
In your current situation: use solder wick (and flux!) to remove the excess solder. Or if you have a hot air soldering station, remove the IC first and start over.
yes I have a hot air station, about the temperature the shop on Aliexpress warns to be careful not to overheat the STM, what temperature should you use?
I'm using the technique in the video below. Cream flux can also be used instead of the flux pen. A toothbrush is enough to apply the cream flux.
I usually have mine set to 330°C but I only have a cheap 858D clone so I can't even be sure it is actually that temperature. For me it is just the setting that usually works. Also, after you desoldered the IC you will probably still want to clean the pads with a solder wick.
On a different note: this is getting somewhat off-topic again. Maybe it is time for the KFF to get its own sub-section like some of the other popular hardware projects? I think that might make it more natural to open separate threads for questions like these. But maybe that is just my opinion...
Abgesehen davon gerät das langsam mal wieder off-topic. Vielleicht wäre es an der Zeit, dass das KFF eine eigene Untersektion im Forum bekommt? Das könnte es möglicher Weise erleichtern, für solche und ähnliche Frage separate Threads aufzumachen. Aber vielleicht bin ich da auch voreilig...
Is there a chance being able to save to Easyflash Images in near future - i think this would be the KILLER FEATURE for the Kung Fu Flash Cartridge.
As with the Ultimate Devices it is rather inconvinient having to name and save to a new image by hand.
On a real EF/EF3 you obviously got limited space for images so it would be veeeeery nice being able to save to EF Format with the bigger Kung Fu Cart.
I am getting mine in the near future - looking forward anyway!!
Yes, it would be a nice feature that I would like to have but also one that isn't that trivial to implement. So unless somebody else is working on this you might have to wait a bit longer than 'near' future
So as i am not able to implement Easyflash saving to the Kung Fu Cartridge either: Volunteers first!!!
Sagt mal, habe ich irgendwo überlesen das es mit dem Ultimate64 im Zusammenspiel mit dem KKF Probleme gibt?
Bei mir flackert nur die LED, sobald ich das Teil in Betrieb nehme.
Auf einem normalen C64 jedoch kein Problem.
Ich weiß nicht, ob das schon irgendwo thematisiert wurde, aber bei mir funktioniert das KFF auch nicht am U64. Das Timing ist für den Controller auf dem KFF schon sehr eng. Persönlich finde ich allerdings, dass das mehr ein Problem des U64 ist, denn das möchte sich ja exakt wie ein C64 verhalten.
Andererseits, am U64 braucht man eigentlich auch kein KFF.
Moin,
ich habe da mal eine Frage.
Mein KFF hat keine USB Öffnung im Gehäuse. Jedoch die Platine ist voll bestückt.
Ich habe es aber auch noch nicht ausprobiert.
Es gibt da doch keine Unterschiede, oder? Wollte jetzt auch nichts kaputt machen...
Meine Konfiguration mit den EF3 funktioniert. Kann ich die so auch mit dem KFF ausprobieren?
Nein, es gibt keine relevanten Unterschiede zwischen den beiden Revisionen. Der Hauptunterschied bei Rev.2 ist, dass die USB-Buchse nun so sitzt, dass man dafür sinnvoll Öffnungen im Gehäuse vorsehen kann.
Das erinnert mich daran, dass ich die neuen STLs zu meinem Gehäuse noch aufbereiten und veröffentlichen wollte. Schaffe ich heute allerdings vermutlich nicht mehr...
Okay, ich habe mein Gehäuse auf Thingiverse aktualisiert und die Dateien für das Rev.2 Gehäuse hochgeladen. Es scheint allerdings, als müsste dort noch der Cache aktualisiert werden:
https://www.thingiverse.com/thing:4153414
Okay, I updated my case on Thingiverse and added the two additional files for the rev.2 case. It looks like they need to refresh their cache, though:
hello
I managed to build my Kung Fu Flash with your advices it was a success, but I can not make it work in USB, my PC recognizes it but with a yellow exclamation mark!
if I understood correctly there are no drivers, Kung Fu Flash must be recognized as COMx
There is no need to install a driver, but internet connection may be needed. My Windows 8.1 PC first recognizes the KFF as "Kung Fu Flash" in Device Manager, then searches for its driver. At that moment PC must be connected to the internet, otherwise the driver can't be found and a yellow exclamation mark appears. If PC has internet connection, then the driver is being installed and KFF shows up as "STMicroelectronics Virtual COM Port (COMx)" under the ports section of Device Manager.
