Wenn jemand zu viele der Platinen hat, wuerde ich gerne Eine oder Zwei abnehmen.
Kung Fu Flash Cartridge
- kim_jorgensen
- Thread is Unresolved
Ich habe mir 5 Stück zum Testen bestellt, kannst davon gerne eine haben. Allerdings sind meine nur in HASL.
Cool, ich nehme gerne eine. Ich schreib Dir 'ne PN und ob HASL oder ENIG ist eigentlich egal.
Danke!
Habe ja eins geschenkt bekommen, das Ding ist total geil!!!!
Jetzt muss ich nur noch meine eigenen fertig kriegen, muss immer noch die Bauteile bestellen.
kim_jorgensen Do you happen you have an exact link to the USB connectors you have used? That would be very helpful, my first attempt turned out to be a close miss:
CapFuture1975 Boa, Du kriegst ja tolle Geschenke!
Yeah, there are a lot of micro USB connectors out there without any real part number. I used this one https://www.aliexpress.com/item/32986503365.html
Great
but I think soldering U3 is a bit to heavy for my skills
Great hardware for a great computer
It looks scary at first but comes with practice
. There are services in China that can do the assembly for you, but that is not something I have tried yet.
Frenetic found a small bug which prevented the use of Action Replay v7.5 and possibly others CRT files with an invalid header.
This has now been fixed in a new small release which also adds support for Fun Play 64/Power Play 64 and Dinamic CRTs.
Thanks! I went right ahead an ordered a few of those. You can't have too many components lying around, right?
But it turned out that the USB connector was the only component I got wrong, nothing else was missing. So I went ahead and assembled one of the cartridges:
After some fighting with one of the fake ST-Link programmers (which turned out to be broken) I managed to program the MCU with a second one I had. Everything seems to be working as expected now. Awesome!
I had actually noticed that AR 7.5 wasn't working on my first run, too. But I can confirm that it does now with the new firmware version. Also, the firmware update via SD card works like a charm. The only thing that I failed to get running so far is the Super Snapshot 5 cartridge. With all CRT files I have I only get a black screen so far.Anyway. Thanks again for sharing this great project! I can't wait to dabble with the firmware myself a little. I only there was more time...
Nice work, thank you for sharing bigby
I'll like to reproduce this. Which versions did you try? And did you try it on different C64? Maybe there is a problem with the timing for this cartridge type.
Happy hacking...
I tried both "Super_Snapshot_v5.22_v1_1990_PAL.crt" and "Super_Snapshot_v5.22_v2_1990_PAL.crt" that I found in the archive on Pokefinder. I haven't had the time to try different C64 yet but I will do so, of course. The one I tried so far has a 250425 board with all original ICs except for the Kernal ROM which is currently replaced with a MagicFlash64.
I used the same CRT files, so it must be something hardware related. I'll try to retest on a 250425 within a week or so.
What a cool Cartridge! Thank you kim_jorgensen for making it open source!
I will order some PCBs now.
Habe ENIG mit Golden Fingers (also hartvergoldete Kontakte) bestellt, war auf jlcpcb.com nicht wirklich teurer.
Nice. Did you also choose the "45° finger chamfered" option?.
Please post some pictures once when you get it assembled.
Yes, I choose that option. I will post pictures, but it can take some weeks, since I used cheaper shipping option.
bigby Is it OK if I use your picture for updating the GitHub page?
Yes, of course. No Problem!
kim_jorgensen Would you mind sharing the cartridge case label with us, too? I'm currently working on a 3D printed case for the Kung Fu Flash and I would love to label it "officially" when it is done...
Man das gibt´s doch nicht!
Hab ich das doch glatt nicht mitbekommen.
Wo ist der Prototyp für meine Sammlung!
