Hello, Guest the thread was called396 times and contains 1 replay
last post from GenerationCBM at the
Best C64 emulator for displaying graphics?
  • Hi!
    I'm really 128er but sometimes I'm creating comparison between VDC, VIC-I, VIC-II and TED.
    I have for displaying graphics C128 and C16+4 emulators which displays all correctly
    Z64K - best C128 emulator at all - in case of graphics has also deinterlacing option in three choices
    YAPE - displays all possible - screenshot is possible to do really good, but interlace of screenshot is not best
    But C64 has too many emulators and when I try to find any it is like blind tip - count of emulators is large.
    I know that maybe VICE is best C64 emulator - correct me if is it not true - but VICE has no deinterlacing option.
    I know that waiting from C64 emulator any deinterlacing option is for many users useless 'cause VIC-II supports not interlace.
    Really what is called on other platforms interlace it expands resolution and mix colors, but C64 only swaps frames without resolution change - really it is according to FLI named flexible line interpretation, no interlace.
    Swapping frames allows to get 136 colors , but resolution is not changed. So anyone from you can ask - why you need deinterlacing?
    Simple: swapping frames produces flickering what is common also in real interlace - this I need to remove to create progressive scan.
    And here it meets problem - progressive scan joins together even and odd frames - and this C64 produces not. So, exist any emulator which mix colors? Or produces stable picture like progressive scan?
    BTW: I understand not C64 designers why they removed from VIC-II chip interlace option 'cause VIC-I, VIC-IIe and VIC-III this option have. It is not fair for C64 users.
    Thank you for recommendations.
    Miro
  • I know that maybe VICE is best C64 emulator - correct me if is it not true - but VICE has no deinterlacing option.
    "Best" is a relative term - Vice is pretty damn good and the best in many areas. Others have other strengths and weaknesses. That said, it's all a matter of taste. In terms of accuracy of the output, the one thing that Vice has over any other (as far as I remember) is the perfect aspect ratio of C64 pixels (narrowed by a factor of 0.937 if memory serves). I think every other emulator just maps the pixel width 1:1 to the host computer. Other than that, Micro64 is generally considered to be the most to-the-bone accurate C64 emulator, particularly with regard to display/output options.
