Hello, Guest the thread was called2k times and contains 4 replays
last post from marty at the
Neues Firmware fuer Ultimate 2+ und/oder Ultimate 2
  • Und es gibt wieder ein neues Firmware Release 3.6 mit einigen grossen Anpassungen und neuen Features
    fuer das Ultimate 64 (incl. Elite), fuer das Ultimate 2+ und sogar auch fuer das alte Ultimate 2 Modul:
    Ultimate 2+
    Latest Firmware for the Ultimate-II+, version 3.6
    Click here to download (please scroll down!)
    Differences with previous release V3.4c
    • General Usability
      • Added possibility to load / save and reset configuration settings
      • Added the possibility to have temporary configuration settings
    • Improvements to SID player
      • Built-in SID player now supports MUS files as well (including stereo tunes)
      • Added support for toggling screen on/off in Sidplayer with S key.
      • Added support for song length in SID header.
      • Fixed correct SID model selection for SIDFX boards
    • Various other bug fixes
      • Copying a file from a container now restores extension
      • Fixed issue of copying file from .t64 files
      • Added 'Enter' option for .t64 files
      • User Interface improvements / fixes
      • Fixed telnet connection - removing header upon connect (fixes random copy actions)
      • Changed default hostname to match target
    1541 Ultimate-II
    Latest firmware for the 1541 Ultimate-II is version 3.6
    • General Usability
    Ergänzung markusC64: Gideon hat eine wesentliche Änderung nicht genannt:
    * Easyflash Seiten löschen erheblich schneller, dadurch wesentlich bessere Performance beim Speichern im Easyflash.
  • Und es gibt wieder ein neues Firmware Release 3.7 mit Bugfixes und neuen Features
    https://ultimate64.com/Firmware
    Firmware release 3.7 is online for all targets:
    U64 - Core version V1.28
    Ultimate II+
    1541 Ultimate-II
    Online documentation has been added. Special attention was given to the added modem emulation layer,
    https://1541u-documentation.re…n/latest/howto/modem.html
    and the extra debug streams for the U64 -
    https://1541u-documentation.readthedocs.io/en/latest/data_streams.html#debug-stream-id-2 .
    Damit die Firmware fuer das U2 noch gebaut werden konnte, musste der Compiler auf "Optimized for size" umgestellt werden.
    So wurde die Firmware nun 40 kByte kleiner und passt noch in den Speicher der U2 Cartridge.
    Dadurch war es moeglich das "Modem Feature" auch fuer U2 aufzunehmen, welches mit dem USB2LAN Adapter genutzt werden kann.
  • Die neue Firmware 3.10 wurde soeben fuer Ultimate 64, Ultimate 2+ und fuer Ultimate 2 mit neuen Features und Bug Fixes frei gegeben.
    Fuer das alte Ultimate 2 Modul gibt es, auf Grund der Speicherknappheit, nun 3 verschiedene Versionen der Firmware:
    update_3.10_au.u2u -> ein Floppy Laufwerk und Audio (SID)
    update_3.10_dd.u2u -> zwei Floppy Laufwerke und Modem
    update_3.10_gm.u2u -> ein Floppy Laufwerk und komplette gmod2 Unterstuetzung (incl. Eeprom)
    [Nachtrag: Für die 1541 Ultimate II ohne Plus ist dabei leider ein Fehler unterlaufen, die Datei update_3.10_gm.u2u hat fälschlicherweise den selben Inhalt wie die Datei update_3.10_dd.u2u. Die Version der Firmware, welche GMOD2 unterstützt, wird Gideon also nachliefern müssen - ich habe ihn gerade per E-Mail informiert.]
    [Nachtrag 2: Gideon hat soeben eine korrigierte Release hochgeladen.]
    Eine Tabelle mit der Uebersicht welche Version welche Features unterstuetzt findet ihr hier:
    https://1541u-documentation.re…howto/installing_310.html
    Hilfe zu den neuen Features findet Ihr hier:
    https://1541u-documentation.re…aster/howto/mm_drive.html
    Firmware 3.10 now available for download!
    https://github.com/GideonZ/ult…/master/ultimate_3.10.zip
    Changes since official release (3.9 / 1.37)
    Added features:
    - Hardware emulation of 1571 and 1581 drives (U2+ / U64 only)
    - MFM support on 1571, with enhanced G71 format to store MFM tracks
    - Added audio samples for insert / remove floppy disk
    - Added second drive sound to speaker output
    - Possiblity to use your own drive sound samples
    - Custom U64 palettes
    - SystemInfo Page, showing drive, cartridge and storage status
    - Flash Disk, to store drive roms, sounds, cartridges and such
    - Cartridges are now always CRT files. Selected by filename in the config
    - Cartridge compatibility check and reporting
    - GMOD2 support, including EEPROM (U2+ / U64 only)
    - Zaxxon Cartridge support
    - Implemented writing CVT files back to a disk image (enables copying CVT files across disks.)
    Various UI Improvements:
    - Select & Delete, using Shift-DEL
    - Recursive delete from context menu
    - Long filename truncation (thanks to 'naali' / Antti Svenn)
    - Scrollable string edit box
    - Adds save function for all cartridges, including EasyFlash and GMOD2
    - Full Clear function of configuration in Flash
    - Added 'F3' Help screen to config menu
    Technical Fixes:
    - Fixed RGB mode (U64 only)
    - Fixed block read command
    - Fixed access of files with special chars in CBM disk images, accessed from IEC
    - Fixed UCI issues with SidPlay and others
    - Fixed colon issue in Ultimate Kernal ROM
    - Fixed crash on invalid file chain CBM filesystems
    - Fixed check order DIR / VOLUME; fixes some issues with exFAT directories
    - Added M and V commands in modem emulation layer, V now supporting numeric responses. Thanks Scott Hutter
    - Fixed the root cause of the VOLUME bit set in exFAT directories
    - Fixed missing 'probe' for filesystems on multi-partition disks
    - Fixed loading from wrong device ID when issuing the 'run disk' command
    - Fixed many little bugs in the generation of CVT files (copying GEOS files from a disk image)
    - Adopted changes to U64 Kernal to set default loading ID, as submitted by Leif Bloomquist
    - Adopted USB modifier key handling, as submitted by Peter de Schrijver
    - Corrected bug in extended partition table reading
    - Relaxed C128 cartridge timing (for C128 carts)
    - Extended UCI I/O bytes to support Hyperspeed Kernal properly
    - Check for file copy onto itself
    - Increased robustness against loading faulty disk images
    - Fixed VIA latch mode in 1541/1571.
    - [Issue 227] Fixes 'get sensible name' function for Ulticopy
    - Fix for .d71 sector allocation - format should give 1328 blocks free, not 1347.
    - Fixes possible crash when decoding a GCR track to binary
    - [Issue 160]: SpeedDOS / DolphinDOS loading errors
  • Post by c64user ().
    This post was deleted by markusC64: Hier nicht... ().
  • 3.10a, with fixes on 3.10 now available for download.
    https://github.com/GideonZ/ult…master/ultimate_3.10a.zip
    Changes in 3.10a, compared to 3.10
    Fixes:
    [Issue-246] Fixed: Virtual Printer crashes when file cannot be created.
    [Issue-234] Deleting last item in directory makes selection invisible
    [Issue-236] Confirmation modal asking a question only gives 'OK' instead of 'Yes/No'.
    [Issue-R17] Added mapping of ESC key to RUN/STOP.
    [Facebook Request] Added: Leave menu on mount (can be selected per drive)
    [Facebook Bug Report]: Allow Maverick (and others?) to write wrong sector headers on MFM tracks.
    [Facebook Bug Report]: Unable to select GeoRAM. Is now a mode of the RAM Expansion Unit.
    [Facebook Bug Report]: Fixed color palette not loaded at boot (U64 only).
    [Facebook Bug Report]: Fixed USB sticks not recognized
    [Messenger Report]: Improvements to palette file read. Rejects faulty files. Fixes hang-up
    [Messenger Report]: Fixes 'Create DNP' when run from Telnet. Turned out to be a stack overflow.
    [Email Discussion]: Adds EEPROM segment to GMOD2 when it is missing in the CRT file
    U2:
    Fixes that U2 updater killed the flash before asking to update, leaving a semi-bricked device.
    Fixes drive sounds.
    Modem:
    ACIA NMI pulse extension to extend over bad line. This allows the 6502 to see it always.
    Performance optimization ACIA / Modem
    Allow spaces after ATDT command.
    Cartridge Support:
    Additional C128 cartridge variant that allows banking and offers some RAM (U2/U2+ only).
