Hello, Guest the thread was called856 times and contains 2 replays
last post from marty at the
Neues Firmware fuer Ultimate 2+ und/oder Ultimate 2
  • Und es gibt wieder ein neues Firmware Release 3.6 mit einigen grossen Anpassungen und neuen Features
    fuer das Ultimate 64 (incl. Elite), fuer das Ultimate 2+ und sogar auch fuer das alte Ultimate 2 Modul:
    Ultimate 2+
    Latest Firmware for the Ultimate-II+, version 3.6
    Click here to download (please scroll down!)
    Differences with previous release V3.4c
    • General Usability
      • Added possibility to load / save and reset configuration settings
      • Added the possibility to have temporary configuration settings
    • Improvements to SID player
      • Built-in SID player now supports MUS files as well (including stereo tunes)
      • Added support for toggling screen on/off in Sidplayer with S key.
      • Added support for song length in SID header.
      • Fixed correct SID model selection for SIDFX boards
    • Various other bug fixes
      • Copying a file from a container now restores extension
      • Fixed issue of copying file from .t64 files
      • Added 'Enter' option for .t64 files
      • User Interface improvements / fixes
      • Fixed telnet connection - removing header upon connect (fixes random copy actions)
      • Changed default hostname to match target
    1541 Ultimate-II
    Latest firmware for the 1541 Ultimate-II is version 3.6
    • General Usability
    Ergänzung markusC64: Gideon hat eine wesentliche Änderung nicht genannt:
    * Easyflash Seiten löschen erheblich schneller, dadurch wesentlich bessere Performance beim Speichern im Easyflash.
  • Und es gibt wieder ein neues Firmware Release 3.7 mit Bugfixes und neuen Features
    https://ultimate64.com/Firmware
    Firmware release 3.7 is online for all targets:
    U64 - Core version V1.28
    Ultimate II+
    1541 Ultimate-II
    Online documentation has been added. Special attention was given to the added modem emulation layer,
    https://1541u-documentation.re…n/latest/howto/modem.html
    and the extra debug streams for the U64 -
    https://1541u-documentation.readthedocs.io/en/latest/data_streams.html#debug-stream-id-2 .
    Damit die Firmware fuer das U2 noch gebaut werden konnte, musste der Compiler auf "Optimized for size" umgestellt werden.
    So wurde die Firmware nun 40 kByte kleiner und passt noch in den Speicher der U2 Cartridge.
    Dadurch war es moeglich das "Modem Feature" auch fuer U2 aufzunehmen, welches mit dem USB2LAN Adapter genutzt werden kann.
