Serial port?
Es gibt 6 Antworten in diesem Thema, welches 1.031 mal aufgerufen wurde. Der letzte Beitrag (3. August 2016 um 13:32) ist von Meshuggah333.
  • Is a serial port on the road map? A standard DB9 serial port would instantly add MIDI output capability. Controlling an old school Roland Sound Canvas with a crazy powerful 8 bit machine sounds like instant awesomeness to me :D
  • Hello,
    Yes, we are intending to implement the C65’s serial port that shares pins on the User port, but is a real UART. From memory, it explicitly supports MIDI baud rates.
    Paul.
  • So that means homemade User port cable to serial/MIDI, that fine by me :)
    Maybe I misunderstood you, that means a real serial port sharing pins with the user port??
  • Yes, that is our current expectation, that we will implement the C65 UART, the same way the C65 did: When you set the registers to turn the UART on, it takes control of several pins that are normally controlled by the CIAs on the user port.
  • Nice, are the level TTL or standard serial? Or will it need something like a MAX232 to connect to standard serial peripheral?
  • So it won't be as easy as I thought it would haha. No big deal.
