Hello, Guest the thread was called637 times and contains 7 replays
last post from mega65 at the
Problems + workarounds with the current (2019-04-23) mega65-core
  • Hi,
    I have tried building the mega65-core today (2019-04-23) and I've ran into some problems while running "make" in mega65-core "develpment" branch, commit 29b952e.
    TL;DR I had to fix some build errors manually, mostly files not being in expected paths. I had to comment out the uart monitor support as I didn't know how to fix it, but finally got the bitstream file built and working. As a result, I can't use monitor_load, but can still program the board with fpgajtag.
    My target is nexys4ddr.
    Here are the problems I ran into:
    1st failure:
    Makefile:419: =============================================================
    Makefile:419: ~~~~~~~~~~~~~~~~> Making: src/utilities/vfpgatest.prg
    Ophis/bin/ophis -4 src/utilities/vfpgatest.a65 -l src/utilities/vfpgatest.list -m src/utilities/vfpgatest.map -o src/utilities/vfpgatest.prg
    src/utilities/vfpgatest.a65:417: Could not read ../../assets/vfpga-bitstream.bin
    1 error
    make: *** [src/utilities/vfpgatest.prg] Error 1
    Indeed, I don't have that file in mega65-core/assets directory. These are the contents of that directory:
    alphatest.bin
    matrix_banner.txt
    synthesised-60ns.dat
    track2-40ns.dat
    I've copied alphatest.bin to vfpga-bitstream.bin as it was the only file with the same extension. Not sure if that makes any sense in the long run, but it allowed the build to proceed.
    2nd failure:
    ( cd src/verilog ; ../../iverilog/driver/iverilog -tvhdl -o ../../src/vhdl/uart_monitor.vhdl.tmp monitor_*.v asym_ram_sdp.v 6502_*.v UART_TX_CTRL.v uart_rx.v )
    sh: /home/user/mega65-core/iverilog/lib/ivl/ivlpp: No such file or directory
    sh: /home/user/mega65-core/iverilog/lib/ivl/ivl: No such file or directory
    make: *** [src/vhdl/uart_monitor.vhdl.tmp] Error 127
    There is no "lib" directory in mega65-core/iverilog. I see there are ivl and ivlpp binaries with paths mega65-core/iverilog/ivl and mega65-core/iverilog/ivlpp/ivlpp
    So I manually symlinked the files to existing ones:
    mkdir -p /home/user/mega65-core/iverilog/lib/ivl
    ln -s /home/user/mega65-core/iverilog/ivlpp/ivlpp /home/user/mega65-core/iverilog/lib/ivl/ivlpp
    ln -s /home/user/mega65-core/iverilog/ivl /home/user/mega65-core/iverilog/lib/ivl/ivl
    Next error:
    [user@localhost mega65-core]$ make
    ERROR: Unable to read config file: /home/user/mega65-core/iverilog/lib/ivl/vhdl.conf
    Again, seems to be looking for the vhdl.conf file in the wrong directory. Fixed with
    ln -s /home/user/mega65-core/iverilog/tgt-vhdl/vhdl.conf /home/user/mega65-core/iverilog/lib/ivl/vhdl.conf
    I think the build process expects iverilog to be manually installed in (with configure/make/make install), and doesn't work as expected when it's just compiled in the submodule dir. Manually symlinking stuff seems to work.
    Then I got stuck at:
    monitor_top.v:176: error: Unknown module type: monitormem
    2 error(s) during elaboration.
    *** These modules were missing:
    monitormem referenced 1 times.
    make: *** [src/vhdl/uart_monitor.vhdl.tmp] Error 2
    And here I ran out of ideas. I don't know what the monitormem module type is and what should provide support for it. The only files where it is referenced at all are that monitor_top.v and the main Makefile. Maybe I need a different version of iverilog? I don't see a mention of monitormem there even in the master branch.
    Not knowing what to do, I just commented out that monitormem line in monitor_top.v:176
    After that I got more complaints about non-existing files, fixed with
    ln -s /home/user/mega65-core/iverilog/tgt-vhdl/vhdl.tgt /home/user/mega65-core/iverilog/lib/ivl/vhdl.tgt
    Next, ran into this:
    make[1]: Entering directory `/home/user/mega65-core/src/mega65-fdisk'
    cc -o asciih asciih.c
    asciih.c: In function ‘main’:
    asciih.c:6:3: error: ‘for’ loop initial declarations are only allowed in C99 mode
    I guess it's because I'm running this on Centos 7.6 which comes with gcc4.
    Added -std=c99 to mega65-core/src/mega65-fdisk/Makefile:45
    With that the build process continued and finally started building stuff with Vivado.
    Next, I got some errors like nexys4.vhdl not having declared miso_2 input, but all I really needed was the nexys4ddr target so from then on I went with
    make bin/nexys4ddr.mcs
    and finally it built!
    uploaded it to nexys4 with fpgajtag and it worked.
    Would be nice to have the monitor working though since I'm more interested in software development. I'm only a beginner at hardware programming and contributing to the hardware design is beyond my ability at this point.
    regards,
    Terlisimo
  • Hey, thanks for taking the time to look into this!
    I've created a pull request on github.
    I made another one small fix for Ophis, builds failed on my system where python3 is default.
    Could you look into the monitor thing? It seems like monitor_mem.v is missing from the mega65-core/src/verilog directory.
    monitor_top.v is referencing it.
  • Well, really we should just try to move away from Ophis to ca65 or another more supported assembler.
    monitor_mem.v should get built by some other step in the Makefile. Yes, here is the rule:
    $(VERILOGSRCDIR)/monitor_mem.v: $(TOOLDIR)/mempacker/mempacker_v $(BINDIR)/monitor.m65
    $(TOOLDIR)/mempacker/mempacker_v -n monitormem -w 12 -s 4096 -f $(VERILOGSRCDIR)/monitor_mem.v $(BINDIR)/monitor.m65@0000
    Try making the file explicitly, and tell me if you get an error.
    I'll take a look at the pull request -- thanks for that.
    Paul.
  • Great, thanks!
    I'm keen on getting involved with the development. I set out to learn FPGA programming in order to build my own computer from scratch, but the end goal was something like you guys are already doing so I thought I might as well apply my effort here.
    I suppose you have some tasks that are nice to have but not priority, like moving to ca65. I'll give that a shot, unless you have a better idea on what I should get started with.
    BTW, is this the right place to discuss these kinds of things or is some other place preferred? Google group maybe?
