Is there a Mega64 profile for Vice? It would be nice if there was some way to program for this device BEFORE it was actually available so that there was more than just classic Commodore software available for it.
Mean I correctly - VICE emulator?
If yes, we all will be happy if there will be C65. In other way I mean C65 will be there before SCPU128. SCPU64 there is, but sadly Commodore 64 is on the top and other computers like C128 are lower.
For example - many fixes, but long time existing FD-2000/4000 problem in case C128 was not yet fixed. All other computers with IEC bus can use FD-2000/4000.
How to programming M65 - as base can be MESS and its C65 emulator. Many meaning that works not, half is true - new versions of MESS working not, older yes.
Please forgive me (VICE developers) my critical words - really I never saw better emulator of C128 and other Commode 8-bits. But how to programming M65 before release? Easy - write code in MESS and test on Nexys4 - no problem. If you can, use 64TASS assembler.Miro
adtbm
Moved the thread from forum alte Beiträge von MEGA65 to forum XEMU/MEGA65 Emulator. -
People have ideas ...
Alternatively use the XEMU as emulator.
Please, don´t make not the 3rd Step, before the 1st Step,is not finishd it !!!
Brotscheibe
Brotscheibe
Well, I think it is a valid point to ask for evelopement environments even before the system is there.
As more software is in place, when the hardware comes out, the bigger the chance of a success is given.
Ok, that is also an intresting point in this issue.
Brotscheibe
So while, Bodhi1969 dug this one up,
we really would like to have a MEGA65 implementation for Vice.
But this is something, we just can't handle at the moment too.
Our goal would be, to directly implement the MEGA65. Than we would have a common base for c65 compatibility as well.
So if anybody is interested in going forward on that idea, please contact us, we will happily provide you with all support and information neccessarry
and this would be a HUGE step toward -bringing the MEGA65 closer to the community- !
Vergesst den Mist.Vice ist ein Emulator existierender Commodore Computer.
Der C65 wäre vielleicht einer geworden, aber meiner Meinung nach nur, wenn er an statt des C128 vor dem Amiga 500 gekommen wäre.
Also bitte, geiles Gerät zugegebenermaßen.Aber niemand wäre 1988 von 16 Bit auf 8 Bit zurück gegangen.
Und warum soll das Allerheilmittel Vice sein.Ist ein "RECHT GUTER" Universalemulator, der super aussieht.
Aber das mit den 50 Hz.
Da gibt es was Besseres für den Cevi und für den Plus 4 ja auch, die das Scrolling auf 50 Hz Bildschirmen 1a hinbekommen.Ich mag den Xemu ganz gern und würde mich über eine bessere Optik a la CRT emulation sehr freuen, aber ich finde nicht, dass die Verwendung des XEMU das Projekt weiter von jemanden weg bringt, nur weil es VICE ist.
Ich meinte natürlich, nur weil es nicht vice ist.
meinst du mit "vergesst den Mist" deinen Beitrag?
Hi Bloody,
even if german is my native language, i have to admit, that i have certain problems to get to some of the points of your post:
This has nothing to do with : Getting MEGA65/C65 emulation on VICE. this is more a philisophical statement from your own opinion.
I do have the MEGA65 preseries and the Nexys4DDR&Widget variant, so i tell you: The MEGA65 exist ! Based on the specifications Commodore has set and improved by M.E.G.A.
This is exactly the point: Vice is a commonly accepted emulator, which has been integrated into alot of dev tools, like CBM prg studio or c64 studio
as an example, so having the MEGA65 integrated in Vice would be a logical step, to get sooner or later support for those dev tools as well.
Xemu/Mega65 is still our main emulator and that's why i said in my previous post, that it would be nice, if somebody would be interested in getting the MEGA65 implemented. We would support this person as good as we can, but we just don't have the time atm to do it.
from my experience i can say, that for a quick testing of some c64 code, Vice is 100% sufficent. But i have to test my code on the real machine anyway.
This is/would be exactly the same for Xemu.
I think, nowadays, most people code on the PC and then they transfer the code to the real (existing
)machine, because that's the only way to ensure for 99.99% that your code will run on most of those real machines...
Wieso 'zurückgegangen'?
Wäre er damals herausgekommen, hätten etliche den gekauft anstatt auf PCs umzuschwenken.
Denn ein wechsel von c16/64/128 auf Amiga hätte sowieso bedeutet das alle vorhandene Bücher, Software und größtenteils auch Hardware neu angeschafft werden mußte, weil inkompatibel.
Schon damals war abzusehen daß der Amiga den PC nicht das Wasser reichen konnte auf langer Sicht.
Für reine Zocker sah das natürlich anders aus. Der Amiga war schließlich ursprünglich ja ein Spiele-Automaten den man eine Tastatur verpaßt hatte.
Arbeitstiere waren PC, Mac und AtariST (im low-end Bereich).
