Hello, Guest the thread was called444 times and contains 2 replays
last post from Ben-401 at the
How many FPGA Logic Cells are currently already used?
  • Hi,
    the "Xilinx XC7A100T" has probably 101440 Logic Cells / 15850 Slices.
    My question is how many of these Logic Cells / Slices are currently already used?
    And how many are therefore still available for enhancements and new features?
    Can I even know which part (VICTOR, BILL, SID, etc.) how many Logic Cells / Slices occupied (approximately)?
    thanks and best regards
    Hans
  • Currently the FPGA is about 70% full, which is as high as I want it to go with all the vital features. In practice, there are a few things that still need including, so I might have to do some optimising to make enough space.
    I think the last time I looked:
    CPU - 25-30%
    VIC-IV - 25%
    Serial debug interface - 5-10%
    But these are only numbers I am pulling from the air from memory. We are doing quite a bit of work behind the scenes at the moment, so I will give some updated figures when they are available.
    Paul.
  • I have just compiled the design from:
    https://github.com/gardners/c65gs/tree/hyperinterruptdebug
    and ISE reports the following:
    in "Synthesis/DeviceUtilization":
    ```Device utilization summary:
    Selected Device : 7a100tcsg324-1
    Slice Logic Utilization:
    Number of Slice Registers: 25033 out of 126800 19%
    Number of Slice LUTs: 43631 out of 63400 68%
    Number used as Logic: 38023 out of 63400 59%
    Number used as Memory: 5608 out of 19000 29%
    Number used as RAM: 5432
    Number used as SRL: 176
    Slice Logic Distribution:
    Number of LUT Flip Flop pairs used: 49141
    Number with an unused Flip Flop: 24108 out of 49141 49%
    Number with an unused LUT: 5510 out of 49141 11%
    Number of fully used LUT-FF pairs: 19523 out of 49141 39%
    Number of unique control sets: 1327
    IO Utilization:
    Number of IOs: 175
    Number of bonded IOBs: 172 out of 210 81%
    IOB Flip Flops/Latches: 100
    Specific Feature Utilization:
    Number of Block RAM/FIFO: 122 out of 135 90%
    Number using Block RAM only: 122
    Number of BUFG/BUFGCTRLs: 7 out of 32 21%
    Number of DSP48E1s: 14 out of 240 5% ```
    and in "PAR/DeviceUtilization":
    ```Device Utilization Summary:
    Number of Slice Registers: 25,003 out of 126,800 19%
    Number used as Flip Flops: 24,963
    Number used as Latches: 20
    Number used as Latch-thrus: 0
    Number used as AND/OR logics: 20
    Number of Slice LUTs: 36,034 out of 63,400 56%
    Number used as logic: 30,129 out of 63,400 47%
    Number using O6 output only: 21,053
    Number using O5 output only: 717
    Number using O5 and O6: 8,359
    Number used as ROM: 0
    Number used as Memory: 5,212 out of 19,000 27%
    Number used as Dual Port RAM: 2,972
    Number using O6 output only: 2,456
    Number using O5 output only: 36
    Number using O5 and O6: 480
    Number used as Single Port RAM: 2,066
    Number using O6 output only: 2,050
    Number using O5 output only: 0
    Number using O5 and O6: 16
    Number used as Shift Register: 174
    Number using O6 output only: 172
    Number using O5 and O6: 2
    Number used exclusively as route-thrus: 693
    Number with same-slice register load: 617
    Number with same-slice carry load: 76
    Number with other load: 0
    Number of occupied Slices: 10,990 out of 15,850 69%
    Number of LUT Flip Flop pairs used: 38,262
    Number with an unused Flip Flop: 19,700 out of 38,262 51%
    Number with an unused LUT: 2,228 out of 38,262 5%
    Number of fully used LUT-FF pairs: 16,334 out of 38,262 42%
    Number of slice register sites lost
    to control set restrictions: 0 out of 126,800 0%
    A LUT Flip Flop pair for this architecture represents one LUT paired with
    one Flip Flop within a slice. A control set is a unique combination of
    clock, reset, set, and enable signals for a registered element.
    The Slice Logic Distribution report is not meaningful if the design is
    over-mapped for a non-slice resource or if Placement fails.
    OVERMAPPING of BRAM resources should be ignored if the design is
    over-mapped for a non-BRAM resource or if placement fails.
    IO Utilization:
    Number of bonded IOBs: 173 out of 210 82%
    Number of LOCed IOBs: 173 out of 173 100%
    IOB Flip Flops: 104
    IOB Master Pads: 3
    IOB Slave Pads: 3
    Number of RAMB36E1/FIFO36E1s: 120 out of 135 88%
    Number using RAMB36E1 only: 120
    Number using FIFO36E1 only: 0
    Number of RAMB18E1/FIFO18E1s: 3 out of 270 1%
    Number using RAMB18E1 only: 3
    Number using FIFO18E1 only: 0
    Number used as BUFGs: 7
    Number used as BUFGCTRLs: 0
    Number of IDELAYE2/IDELAYE2_FINEDELAYs: 16 out of 300 5%
    Number used as IDELAYE2s: 16
    Number used as IDELAYE2_FINEDELAYs: 0
    Number of ILOGICE2/ILOGICE3/ISERDESE2s: 30 out of 300 10%
    Number used as ILOGICE2s: 14
    Number used as ILOGICE3s: 0
    Number used as ISERDESE2s: 16
    Number of ODELAYE2/ODELAYE2_FINEDELAYs: 0
    Number of OLOGICE2/OLOGICE3/OSERDESE2s: 118 out of 300 39%
    Number used as OLOGICE2s: 76
    Number used as OLOGICE3s: 0
    Number used as OSERDESE2s: 42
    Number of PHASER_IN/PHASER_IN_PHYs: 2 out of 24 8%
    Number used as PHASER_INs: 0
    Number used as PHASER_IN_PHYs: 2
    Number of LOCed PHASER_IN_PHYs: 2 out of 2 100%
    Number of PHASER_OUT/PHASER_OUT_PHYs: 4 out of 24 16%
    Number used as PHASER_OUTs: 0
    Number used as PHASER_OUT_PHYs: 4
    Number of LOCed PHASER_OUT_PHYs: 4 out of 4 100%
    Number of BSCANs: 0 out of 4 0%
    Number of BUFHCEs: 0 out of 96 0%
    Number of BUFRs: 0 out of 24 0%
    Number of CAPTUREs: 0 out of 1 0%
    Number of DNA_PORTs: 0 out of 1 0%
    Number of EFUSE_USRs: 0 out of 1 0%
    Number of FRAME_ECCs: 0 out of 1 0%
    Number of IBUFDS_GTE2s: 0 out of 4 0%
    Number of ICAPs: 0 out of 2 0%
    Number of IDELAYCTRLs: 1 out of 6 16%
    Number of IN_FIFOs: 2 out of 24 8%
    Number of LOCed IN_FIFOs: 2 out of 2 100%
    Number of MMCME2_ADVs: 2 out of 6 33%
    Number of LOCed MMCME2_ADVs: 1 out of 2 50%
    Number of OUT_FIFOs: 4 out of 24 16%
    Number of LOCed OUT_FIFOs: 4 out of 4 100%
    Number of PCIE_2_1s: 0 out of 1 0%
    Number of PHASER_REFs: 1 out of 6 16%
    Number of LOCed PHASER_REFs: 1 out of 1 100%
    Number of PHY_CONTROLs: 1 out of 6 16%
    Number of LOCed PHY_CONTROLs: 1 out of 1 100%
    Number of PLLE2_ADVs: 1 out of 6 16%
    Number of LOCed PLLE2_ADVs: 1 out of 1 100%
    Number of STARTUPs: 0 out of 1 0%
    Number of XADCs: 1 out of 1 100%```
