Is possible to run AmigaOS 3.9 on MiST?
  • Hi!
    I have installed on one hardddisk image for WinUAE AmigaOS 3.9.
    I want to use it with MiST, but at beginning of boot it reports failure and I don't know where is problem.
    AmigaOS 3.9 is installed by friend, so I don't have skill in this way...
    Is possible to run by any way AmigaOS 3.9 on MiST?
    Thank you very much.
    Miro
  • Hi Kris...
    Other way - the same friend has real AmigaOS 4.1... running on real Amiga - is it possible to use it in WinUAE and even harddisk image in MiST?
    My hopes are small, I know that friend bought OS, so maybe, only maybe will create ISO and if it will be reality, maybe installs it to WinUAE...
    Is posssible to use AOS4.1 on MiST?
    Why I'm asking?
    I'm user and programmer of Commodore and other 8-bits... I see also Apple and its way to Macintosh - similar to Commodore 6502 > 65816 > 68000
    And have at home real MacSE - I'm using Apple II in MiST, I can compare.
    I owned in 90's Amiga 500 and then 1200, but sold it away and stay with my 8-bit...
    Now, comparing Apple II > Apple IIGS > MacSE want to see Commodore 128 > SuperCPU128 > Amiga - but Amiga own not, so rather than emulator want to use MiST, I have at home modded DTV and really see how can be C64 improved...
    Miro
