QuoteAdd support for YPbPr video.
Hello, Guest the thread was called7.6k times and contains 21 replays
last post from Larry Underwood at the
Aktuelle Core für Commodore 64 12.01.2017
Hi Kris!
I tried to use new C64 core same way like C16.
To Commodore 16 I added to root directory c16.rom - Kernal with JiffyDOS and it works - JiffyDOS is available.
Commodore 64 core before this new could have any ROM in root directory and always ignored it.
New Commodore 64 core I used same way like C16 - I added to root directory c64.rom - but it hangs with clear screen - no text, only paper and border.
I used JiffyDOS 6.01, Japanese Kernal and original Kernal - each in correct size 8K = 8192 B.But this core ignores not ROM named c64.rom - so, how to use custom ROM, maybe JiffyDOS or other?
Each idea is welcome.
Miro -
Hi!
ROM file fixed, but not fully.
I was playing around ROMs and tried to add chargen and Basic.
So, after testing I got to work combination joined together into c64.rom:
Basic ROM + Kernal ROM + Character ROM
In this order I successfuly got to work JiffyDOS.
All works, JiffyDOS commands too - but - disk access hangs...Any idea?
Miro -
Sorry, i have no idea. I dont own the jiffy dos ROM. Maybe you have to ask the autor of the c64 core or the guy who created the 1541 part.
I tried the same with the same result. The screen turns blank... blue but blank... the menu appears after F12.
Nice idea to get Jiffydos running. hope it will work some day- - if so please inform how... thx!
Auf Facebook in der Gruppe "MIST FPGA Computer" liegt ein neuer C64 Core zu Download.
Er soll jetzt auch T64 Dateien laden können.https://lookaside.fbsbx.com/fi…qKPny--qpzyPnVp3NCd4gILIg
Ich weiss nicht ob ich den hier einfach so zu DL anbieten darf. Deshalb lass ich das jetzt besser.
Gruß Olaf
Kein Problem! Natürlich kannst du den Core hier bei uns anbieten und hochladen. Ich fände es toll!
Using JiffyDOS with C64 core:
create ROM file named c64.rom in this order:
Join together basic + kernal + 1541 ROM by copy /b
Basic - not yet tested other than 2.0 - req'd size: 8K
Kernal - JiffyDOS or other - req'd size: 8K
1541.ROM - JiffyDOS or other - req'd size: 16Kplace c64.rom into root directory of SD card
If you want to use JiffiyDOS incl. faster R/W both Kernal and 1541.ROM must to be JiffyDOS.
or you can create custom machine, only one feature is missing for machine customize - chargen.Miro
Hier ein neuer C64 Core vom Facebook Mitglied "Lee Ashmore" aus der MIST FPGA Computer Gruppe.
Er soll T64 Dateien lesen können.Falls es mit der gezippten Datei Problem gibt, bitte melden.
Am Besten per PN.Viel Spaß
dg5fdg -
Danke! Gibt es zu der Datei auch noch ein Changelog? Wäre interessant zu wissen, welche Neuerungen in den Core eingeflossen sind.
Sorry wenn jetzt erst Antwort. Hatte viel um die Ohren die letzten Wochen.
Die Frage mit den Changelogs kann ich leider nicht beantworten.
Dazu hat der Programmierer leider nichts geschrieben. -
"Lee Aschmore" hat eine neue version auf facebok veröfentlicht C64_mist 3_jun_27.zip
https://www.facebook.com/groups/1501669116809347/files/
QuotePlease find attached - JIFFYDOS FIXED.
cart working as before - standard , ultimax and ocean good.
Danke für den Info! Hab dein Beitrag schon in Forum64 gesehen
Hallo,
Bei C64 Core kann man auch wenn man was in Basic schreibt speichern ?
save "test " ,8 oder so ?
Ja, müsste so gegen. Zuerst aber muss ein leeres Diskettenimage geladen werden. Muss ich auch noch Mal angucken.
Auch auf facebook, ein andere version (datum, grösse) ?
https://www.facebook.com/group…6809347/1718247855151471/
Lee Ashmore uploaded a file in the group: MIST & MISTer FPGA Computers.
September 24
OK..... small update to 1541 write code to allow rom to detect disk changes......
C64_mist_1541_write.rbf · version 1
Jepp, haben wir schon erfasst.
Siehe Beitrag unter Bekanntmachungen.Da ich nicht auf Facebook unterwegs bin bekomme ich einige Neuentwicklungen leider nicht mit. Da bin ich verstärkt auf euch angewiesen.
Kleines Update am Core,
unterstützt nun CRT (Cardridge) Files und den 2. Feuerknopf -
Cool! Muss ich unbedingt demnächst ausprobieren!
