Hello, Guest the thread was called3.2k times and contains 2 replays
last post from Negan at the
Aktuelle Firmware 14.01.2017
  • und wieder eine kleine Verbesserung:
    Quote
    firmware_170114
    - Prevent pass modifier keys while OSD is active. Fix modifier codes in keyboard test for non-8bit cores.
    - Remap key INSERT to \ for Minimig core.
    noch ein kleiner Nachtrag:
    Quote
    firmware_170113
    - Send INI config to FPGA earlier (fix Minimig nag screen synchro).
