und wieder ein größeres Update:
ZitatAlles anzeigenfirmware_160616
- Minimig: added joystick, keyboard tests, and USB status display to OSD.
- Minimig: new MIST.INI option, 'key_menu_as_rgui', set to 1 to bind 'Menu' USB key to Right Amiga key
- 8Bit core: bind Menu key to OSD open
- 8Bit core: ability for cores to declare custom labels e.g. "Load *.DSK 1 / Load *.DSK 2"
- Code refactoring to reduce binary size (saved ~2 KB)
und hier die neuen Optionen für "MIST.INI":
ZitatAlles anzeigen[mist]
scandoubler_disable=0 ; set to 1 to run supported cores in 15khz
mouse_boot_mode=0 ; set to 1 if a mouse does not work well
joystick_disable_shortcuts=0 ; set to 1 to remove joystick -> keyboard commands
joystick_ignore_hat=0 ; set to 1 if having issues on gamepads with 'POV hat'
joystick_ignore_osd=0 ; set to 1 to prevent gamepad from controlling OSD
key_menu_as_rgui=0 ; set to 1 to bind Menu USB key to RGUI (=Right Amiga in Minimig)
joystick_remap=0583,2060,1,2,4,8,10,20,20,8,1400,2800,40,80
joy_key_map=1000,E2
joy_key_map=2000,E6
joy_key_map=4,51
joy_key_map=8,52
