Naaabend zusammen,
leider finde ich hier keine Info - bis zu welcher Größe verträgt die 1541 Ultmate II USB Speicher Sticks?
Wenn ich meinen 32 GB Toschiba reinbastel dann stürzt der C64er ab... kann das an der Größe liegen?
Gruß aus Kölle
Lazy
letzter Beitrag von gintronic am
Naaabend zusammen,
Gruß aus Kölle
Lazy
Was heißt "stürzt ab"... hängt er nur?
Zitat
Known issues
- The processing speed of the Ultimate-II+ is currently (V3.2) stillquite a bit lower than the Ultimate-II. This is because theUltimate-II+ platform does not have instruction/data caches still onits embedded processor. The lower speed may cause some situations inwhich the unit appears to hang, while it is just busy. For example,when the unit is trying to find a free sector on a large USB stick(and note: even 8 GB is already huge!), it may take up to half aminute or so, before the first file can be written, or the firstdirectory can be created. Similarly, when using the printeremulation, the conversion from a bitmap image to a PNG file can takequite some time. This may be solved in a future software upgrade.
Ansonsten steht im Manual noch was zu den Ports...
ZitatUSB support
The Ultimate-II+ supports most USB sticks and Flash card readers out ofthe box. It also supports USB 2.0 Hubs. It is recommended to use poweredUSB hubs only (with an external power supply). USB 1.1 Hubs are notsupported.
There are three USB 2.0 ports available on the cartridge; two on theright and one on the left side. Please note that the port on the left isnot a USB 3.0 port. Although you may use this port as a 2.0 port, itis not USB 3.0 compliant. The extra signals on a USB 3.0 connector areused to communicate with the tape port (see below). Please do notattempt to attach a USB 3.0 device to the blue USB connector on theUltimate-II+. You may safely use a USB 3.0 device on the right sideof the cartridge.
An der Größe liegt es nicht, das Ultimate 1541 II mag nur nicht jeden Stick.
Hol2001 hat z.B. eine große Festplatte(ext. Spannungsversorgung) dran, die hat glaub ich 1 Terra, mit dem gesamten Assembly64.
Der USB-Stick muss FAT32 formatiert sein und MBR muss sich auch drauf befinden. Beim Formatieren sollte man eine kleine Clustergröße wählen, das spart später Speicherplatz.
Ok Danke für die Tipps dann werde ich mal ein par andere Sticks ausprobieren und den Toshiba für Filme nutzen - Hätte jetzt gedacht das es an der Grösse liegt.
