SD2IEC : I/O ERROR #5
Es gibt 3 Antworten in diesem Thema, welches 1.571 mal aufgerufen wurde. Der letzte Beitrag (16. Februar 2019 um 23:55) ist von mrr19121970.
  • I am using FileLoad V2.1.2 Bitte melde dich an, um diesen Link zu sehen.
    And get the error "SD2IEC : I/O ERROR Bitte melde dich an, um diesen Link zu sehen.", however I have no idea what it means. Can anyone assist?
  • Ich kenne das Programm nicht, aber falls es sich dabei einfach nur um Kernal-Fehlernummern handelt, gilt diese Liste:
    0 = BREAK
    1 = TOO MANY FILES
    2 = FILE OPEN
    3 = FILE NOT OPEN
    4 = FILE NOT FOUND
    5 = DEVICE NOT PRESENT
    6 = NOT INPUT FILE
    7 = NOT OUTPUT FILE
    8 = MISSING FILE NAME
    9 = ILLEGAL DEVICE NUMBER
  • 5 = DEVICE NOT PRESENT
    yes, this is it.
    it is almost impossible to debug on a real C64, and the SD2IEC won't run under VICE (emulated or with ZoomFloppy). I put some debug code in after jsr $ffc0 and got $05 back. The strange thing about this, is all loading works upto the game itself. When the game ends and attempts to reloads, then I get DEVICE NOTPRESENT.
    $b7 - $bc are all populated with the correct values.
    I wonder if something like the DD0x direction register is broken causing this issue
  • I finally tracked it down to ZP ($94 used in game) item in $FFC0
    94
    148[td]Serial bus output cache status. Bits:
    • Bit Bitte melde dich an, um diesen Link zu sehen.: 1 = Output cache dirty, must transfer cache contents upon next output to serial bus.
