I am using FileLoad V2.1.2 Bitte melde dich an, um diesen Link zu sehen.
And get the error "SD2IEC : I/O ERROR Bitte melde dich an, um diesen Link zu sehen.", however I have no idea what it means. Can anyone assist?
Es gibt 3 Antworten in diesem Thema, welches 1.572 mal aufgerufen wurde. Der letzte Beitrag (
Ich kenne das Programm nicht, aber falls es sich dabei einfach nur um Kernal-Fehlernummern handelt, gilt diese Liste:
0 = BREAK
1 = TOO MANY FILES
2 = FILE OPEN
3 = FILE NOT OPEN
4 = FILE NOT FOUND
5 = DEVICE NOT PRESENT
6 = NOT INPUT FILE
7 = NOT OUTPUT FILE
8 = MISSING FILE NAME
9 = ILLEGAL DEVICE NUMBER
yes, this is it.
it is almost impossible to debug on a real C64, and the SD2IEC won't run under VICE (emulated or with ZoomFloppy). I put some debug code in after jsr $ffc0 and got $05 back. The strange thing about this, is all loading works upto the game itself. When the game ends and attempts to reloads, then I get DEVICE NOTPRESENT.
$b7 - $bc are all populated with the correct values.
I wonder if something like the DD0x direction register is broken causing this issue
I finally tracked it down to ZP ($94 used in game) item in $FFC0
; send listen on serial bus
ED0C 09 20 ORA #$20
ED0E 20 A4 F0 JSR $F0A4
ED11 48 PHA
ED12 24 94 BIT $94 <<<<<
ED14 10 0A BPL $ED20
Alles anzeigen
| 94 148[td]Serial bus output cache status. Bits:
