Endlich tut sich da mal was...
Schön dass die Jungs vom Hakchi-Team da jetzt auch dran sind...
ZitatAlles anzeigenHi. I am Swingflip, the guy from that video.
I am part of a team that run the community and one of the head devs for the (S)NESC scene.
We are looking to extend our community and software cross platform to other "classic" systems. I always had a soft spot for the commodore 64 and the specs for the c64 mini are pretty good.
I am pretty confident that we will be able to come up with a simple to use interface like we have for the nintendo classics.
I got most of the scripts sorted and the custom environments and libraries sorted. I think PS1 emulation on it will be a stretch but 8/16bit emulation will work perfectly fine.
I just need to rip the UBOOT from the NAND and we will work on a UARTless solution. You will be able to connect to the PC directly with the usb and telnet to the device. The hack will be injected and flashed to nand first boot by booting in FEL using the uboot button and connecting to the PC.
I will rebuild the NANDB image so it nulls the root password too. You wouldn't need a UART or serious technological knowledge to inject the hack on the console (or flash back to stock!)
Anyway nice to see you guys and I will keep you updated with stuff.
BTW if anyone already has the uboot ripped from the C64 please let me know! (It is likely a slightly modified stock A20 uboot)
