Thanks for the info!
Anyone for quick SD2IEC test? Here's the release:
letzter Beitrag von tilobyte am
Tested with current firmware and got "98,UNKNOWN DRIVECODE,200,12" immediately after starting the boot file.
Damn!
Thanks a lot!
I confirm, do not load on SD2IEC.
Wow! What a nice digi sound! Hear this the first time.
Great job! Not on SD2IEC, but on Pi1541.
Thx! There's still hell of a work ahead. I'll post some updates here
Agreed. 8580 recommended. At least the 6581 I am using atm fails here.
Damn!
Thanks a lot!
You're welcome. The reason it doesn't work seems to be that your loader tries to put code into the drives RAM. But that's not what SD2IEC is made for. It can't execute code like a real 1541 or e.g. 1541Ultimate/Turbo Chameleon.
Sure thing. I just thought installer internally recognizes drive type and does some branches (e.g. doesn't send code to drive ram) Game audio is strictly 8580 however sounds better on 6581 than I thought
I am not too much into understanding 65xx code on C64 anymore. But all I could find was a check for the number of drives connected to IEC, not for drive type.
Which loader do you use?
Well, the sd2iec does not prevent drive code uploading in general. It cannot execute it, but either ignores it, or tries to identify certain fast loaders by calculating a checksum.
Schade, da kommt wohl nix mehr?
