A BIG FAT THANKS! ![]()
Easyflash Games - Echte Anpassungen
Stephan Scheuer -
9. Februar 2018 um 19:53 -
Unerledigt
Es gibt 2.489 Antworten in diesem Thema, welches 484.377 mal aufgerufen wurde. Der letzte Beitrag (
Is it possible to disable built in trainer (money etc.) in Bburago Rally cartridge format? Or maybe is there any other version?
did you see this version ?
Das ist doch genau die gleiche Version.
OK
dann bin ich raus
What about the following games ...
Barnsley Badger
Castle Shadowgate
Escape Room
Gravitrix
Hessian
Lost Realms Of Murkasada Episode 2
MAH
Maze Of The Mummy
Miner 2019er
Pains 'n' Aches
Slipstream
Steel Ranger
Von Alter Ego (Male & Female) gibt es ja einen 1581 und einen IDE64 Release.
Wäre es da nur ein kleiner Schritt zu einer/zwei EF Releases des Games, oder übersehe ich da was?
Jedenfalls wäre es toll, solche zu haben.
No problem. Thank you for your helpfulness. Perhaps a solution would be if someone could convert the attached versions, for example.
Alles anzeigen
Barnsley Badger
Castle Shadowgate
Escape Room
Gravitrix
Hessian
MAH
Maze Of The Mummy
Miner 2019er
Pains 'n' Aches
Slipstream
Steel Ranger
Some of the games are onefiler, there's no need of an Easyfash Release.
Steel Ranger -> Just buy it, or is the included Cartridge-Version not Easyfash?
all of the Psytronik versions are already easyflash and physical cartridge to buy, if you can't yet buy them then you can soon.
Alles anzeigenAlles anzeigen
Barnsley Badger
Castle Shadowgate
Escape Room
Gravitrix
Hessian
MAH
Maze Of The Mummy
Miner 2019er
Pains 'n' Aches
Slipstream
Steel Ranger
Really? I thought I had checked every single one! Which ones are OneFiler?
Alles anzeigenAlles anzeigenAlles anzeigen
Barnsley Badger
Castle Shadowgate
Escape Room
Gravitrix
Hessian
MAH
Maze Of The Mummy
Miner 2019er
Pains 'n' Aches
Slipstream
Steel Ranger
Barnsley Badger
Lost Realms... (the game itself is a onefiler)
Mah (the game itself is a onefiler)
Gravitrix -> has a cartridge version in the download
Miner 2019 -> has a cartridge version in the download
Will check, thanks!
Barnsley Badger imo is no OneFiler! Lost Realms of Murkasada Episode II is a OneFiler, correct.
Es befindet sich ein Barnsley Badger PRG in der OneLoad Collection V5.
- Interessanter Beitrag
Irgendjemand hatte letztens nach Gee Bee Air Rally, die Easyflash Version gefragt.
Gee Bee Air Rally von Activision ist soweit fertig. Ob das Spiel 100%ig funktioniert, also das Laden und Speichern, weiß ich nicht. Getestet habe ich ledigllich Level 1 und das Speichern
der High Score, wenn man genügend Punkte bekommen hat. Sollten Probleme auftreten, Bitte einen Snapshot mit WinVice v3.2 anfertigen und eine kurze Beschreibung des Bugs.
Ansonsten, viel Spass mit den Game.
Lieber Stephan,
das war ich VIELEN VIELEN DANK ! -
Lieber Stephan,
das war ich VIELEN VIELEN DANK !Bitteschön. Teste das Game ausgiebig. Ich habe nur das erste Level gespielt. Sollte etwas nicht so funktionieren wie gewohnt, Bitte einen kurzen Bericht verfassen und hier Meldung machen.
Ich bin nur ein EinMann Anpassungsservice, und wenn ich die Games noch durchspielen müsste, würde es mit weiteren Anpassungen bedeutend länger dauern.
My focus is somewhat at different place...
