Hello, Guest the thread was called1.6k times and contains 1 replay
last post from HOL2001 at the
WinUAE 1.1 WIP #1
  • WinUAE 1.1 WIP #1 (07.09.2005)
    Estimated release date: end of september (?)
    Major bugs introduced in 1.0 fixed:
    - Picasso96 graphics corruption after ALT-TAB
    - Zipped Amiga Forever Kickstart ROM image decryption problem
    - JIT FPU ACOS bug (incorrect result if argument was < 0)
    Other bugs fixed:
    - More stable on the fly configuration loading
    - In windowed mode Amiga window height was sometimes slightly
    larger than requested size
    - AHI recording mode memory leak
    - Monitor drivers work now properly (for example Euro36)
    - Incorrect paths if WinUAE was run from networked drive
    - Copper emulation bug (Obliterator intro)
    New features:
    - Configurable Catweasel joystick support, MK4 mouse support added
    - MMKeyboard support added
    - Transparent "drive led status bar"
    - SPTI (Windows 2K/XP) SCSI emulation includes non-CDROM SCSI devices
    - Improved uaescsi.device SCSI interface selection
    - Custom emulation updates (Death Trap, Loons Docs, Spanish Rose by
    Creed, Filled Perspective by Zero Defects, Himalaya by Avalanche..)
    - Improved default path setting, Amiga Forever 2005 paths supported
    - More missing keycodes added to input-panel
    and more..
  • WinUAE 1.1 WIP #2 (11.09.2005)
    Other bugs fixed:
    - "the desktop is too small for the specified window size"-check
    was not completely correct
    - Sprite emulation bug (Elfmania scoreboard)
    - Directory filesystem directory modification date bug if comment
    or protection flags were modified
    New features:
    - Copper debugger
    and more..
