How to dump Recoil supported formats?
There are 4 replies in this Thread which has previously been viewed 1,852 times. The latest Post (June 3, 2017 at 11:13 AM) was by syshack.
  • Hi!
    I know that is possible to find formats supported by Recoil, but it is not possible to use as list separated by comma.
    How can I get dump of Recoil supported file formats extension after extension separated only by comma or similar character?
    I tried command line, but don't know parameters and trying to display help always opened Recoil.
    Thank you very much for help.
    Miro
  • If Please login to see this link. does not answer your question, you might want to re-phrase you inquiry until it can be understood by people other than yourself.
    Yes, I'm the guy responsible for the Please login to see this link. cross assembler. And some Please login to see this link..
  • A list of the supported file format extensions in a CSV file. Is that what you are after?
    Here:
    Meine Kreationen: Please login to see this link. | Please login to see this link. | Please login to see this link. | Please login to see this link. | Please login to see this link.
  • Thank you very much!
    The text file is what I wanted.
    I'm using Windows Explorer replacement XYplorer and there is possible to add many preview formats.
    This Recoil list I need for adding supported extensions.
    Again - thank you very much!
    Miro
  • I just copy/pasted the table from MacB's link into Excel, then selected the extension column copy/pasted it into Notepad++, then Search+Replaced \r\n (Newline) with "," and there you go :D
    You might want to edit the list a bit, some values have a space and a text after the extension.
