How to dump Recoil supported formats?
Es gibt 4 Antworten in diesem Thema, welches 1.803 mal aufgerufen wurde. Der letzte Beitrag (3. Juni 2017 um 11:13) ist von syshack.
  • Hi!
    I know that is possible to find formats supported by Recoil, but it is not possible to use as list separated by comma.
    How can I get dump of Recoil supported file formats extension after extension separated only by comma or similar character?
    I tried command line, but don't know parameters and trying to display help always opened Recoil.
    Thank you very much for help.
    Miro
  • If Bitte melde dich an, um diesen Link zu sehen. does not answer your question, you might want to re-phrase you inquiry until it can be understood by people other than yourself.
  • A list of the supported file format extensions in a CSV file. Is that what you are after?
    Here:
  • Thank you very much!
    The text file is what I wanted.
    I'm using Windows Explorer replacement XYplorer and there is possible to add many preview formats.
    This Recoil list I need for adding supported extensions.
    Again - thank you very much!
    Miro
  • I just copy/pasted the table from MacB's link into Excel, then selected the extension column copy/pasted it into Notepad++, then Search+Replaced \r\n (Newline) with "," and there you go :D
    You might want to edit the list a bit, some values have a space and a text after the extension.
