FRAGE an Samui: welche Verschlüsselung betreibst du denn erfolgreich mit deinem Wifi Adapter,.. bestimmt nicht ohne? oder?
Ich betreibe es mit WPA2
Bei mir gab es keine Probleme. Musste den WLAN-Namen und das Passwort setzen und das Ganze dann einmal abspeichern.
"Assuming you are successfully able to type commands in the terminal window, you now need
to setup the SSID and password of your wifi network into the wifi adapter.
The command to set the SSID is at$ssid=MyWifiNetworkName
Once you have set your SSID you need to set the password.
The command to set the password is at$pass=MyWifiPassword
Once this is done you can attempt to connect to your wifi network by issuing the command
atc1.
Now would be a good time to save the settings to the wifi adapter. If you do not save the
settings then they will be lost when you power off the system. To save the current settings
issue the command at&w. Congratulations! The hard work is over!!!"
