http://www.apollo-core.com/knowledge.php?b=1¬e=2723
Gunnar von Boehn
(Apollo Team Member)
25 Oct 2016 06:07
ZitatAlles anzeigenRoadmap Standalone for AMIGA and ATARI
As many of you will know already, we are working right now on our new card layout - which is optimized for mass production.
Based on the same features we will do both cards for all AMIGA models as also new Standalones.
We expect the first bigger batch of these Standalone to receive this year, and plan to be able to start normal sales beginning of next year.
These standalones can be made both AMIGA and ATARI compatible.
In regards of AMIGA/ATARI chipset one could either instantiate already existing and tested chipsets - or we could work together on merging our SAGA chipset with an ATARI chipset.
As already announced some time ago - we will open source SAGA when its done.
In regards of ATARI Testing and TOS hacking, and also Chipset development - we would need some help - as none of us if experienced here.
So if you are an ATARI expert and want to help to make this happen then please contact us on IRC.
We hope that our standalone from its feature set can give a new live to both retro platforms.
While we have no final price yet - our plan is to offer you the highest possible value, most memory, and best performance for the money.
Gunnar hat mich heute Abend angerufen und mir weitere Details verraten. Es wird auch eine massenproduktionstaugliche Nachfolge-Platine für Vampire 2 geben, mit größerem und noch schnellerem FPGA, die dann im Amiga und ST laufen soll. Die soll dann erstmal in 4-stelliger Zahl produziert werden, um die aktuell 1000 Vorbestellungen zu bedienen. Die Standalone-Version (und vermutlich auch, das hat er nicht erwähnt) die A1200 Karte wird wohl auch darauf basieren. Gunnar sein Team hat halt wenig Ahnung von der ATARI Plattform und braucht da Hilfe. Die Dinger kommen aber so oder so, auch wenn der ATARI Support erstmal suboptimal sein könnte. Er fordert daher die Atari Community auf, zu "liefern", das muss nicht unbedingt VHDL-Code oder Software (Treiberanpassungen) sein, sondern einfach nur Infos, welche Hardwareregister an welcher Adresse gebraucht werden. Der SAGA-Grafikkern von Apollo kann prinzipiell bereits alle ST/STE/TT/Falcon Modis, außerdem auch typische VGA-Modes usw, nur fehlt noch das Registermapping auf komaptible Adressen.
ATARI-Seitig wurden vom Apollo-Team schon zwei Tests gemacht: Amiga 2000 mit Vampire 2 mit an Amiga angepasstem EmuTOS startet. Quickindex Benchmark liefert CPU-Werte, die bis zu 29 mal schneller als ein TT sind. Ein ST wurde mit einer Vampire2 mit TOS 2.06 gestartet, Desktop erschien, aber der Tester konnte nichts weiteres machen. Ob das ein Freeze war, oder ob Tastatur/Maus nicht gingen, weiß man nicht.
