letzter Beitrag von GenerationCBM am
CP/M Software für C64 und C128 auf F64 Wolke
- syshack
- Erledigt
Ich habe das mal "sticky" gemacht, dann geht das nicht unter.
Gruß und Danke
Tom / Pentagon -
How to get whole path?
I failed.Miro
if you are using the web frontend, you have to start with the "software" part of the path.
Maybe I'm dumb - I merged this:
http://www.forum64.de/Software…ut%20Creek%20CPM%20CD-ROM
to webbrowser and result: 404
Miro
You have to follow the link in syshacks post ("F64 Wolke"). There you'll find the access information for the cloud (=wolke). And once you're logged in, you can use the path.
Sadly really is it hidden for external users - no F64 members?
Why?
F64 won't share info/software with others?
I'm surprised - bad.
Reason why you didn't wrote whole path is hide it for others - looks bad...
I mean all of us is own hobby, not reall occupation.Miro
Why?
No, the reason why there is no direct path is that you need to login first and cannot access the content without login.
The F64 Cloud/Wolke has been misused by leechers in the past (downloading all the content at once), up to a point where others from the Forum64 couldn't access it.
So the access permissions are changed every month.However, since you are not an external user, you can simply access it by the web interface or use FTP or RSync (all the details needed are given on the "F64 Wolke" thread).
For the web interface, all information is given on the thread I mentioned:For August 2016 login to:
Link: hidrive.strato.com/share/ustmm50kee
Passwort: AugF642016@C64iiOnce you are logged in, you can navigate to the path I wrote. The web UI looks like this:
Is any of this /public/Forum64_Wolke/Software/CPM/System+Utilities
stil available somewhere to download ?Thank you
stil available somewhere to download ?And you know about this folder....how?
Well it shouldn't be that difficult to find system utilities for CP/M. What are you looking for?
And as for the Walnut Creek collections, ISO images of all that stuff are readily available on archive.org.
