My MMC64 got more stable with Action Replay MK V
Es gibt 7 Antworten in diesem Thema, welches 2.925 mal aufgerufen wurde. Der letzte Beitrag (14. Mai 2005 um 16:14) ist von Kratznagel.
  • Hi!
    Appologizes for writing in English! I can barely read German, and writing is even worse :(
    I have 2 C128's....One US version (NTSC) and one European (PAL) version.
    The PAL version is unstable with MMC64. SID player, diskwriter etc. hangs frequently.
    But after I connected my Action Replay MK V to the MMC64 it become more stable. I seldom have hangs in the SID-player. Diskwriting is also working flawless.
    Im using bios v.0.97
    Just wanted to share this information with you people.
    Will there be a bios-upgrade that enables us to run a program directly from the MMC64??
    This would be a very neat feature!! Diskwriting is veeeery slow....
    Regards,
    Finn Andersen
    Norway
  • Zitat
    This is already possible with "Onefilers"!
  • Zitat
    Yea! But how do you extract files from a .d64 image and beeing able to put them on the SD card?
  • There are several programs which do that. Three of them come to my mind now:
  • Hi,
    Open your D64-Image with D64 Editor or Star Commander, extract one or more of your favorite files, the extension .prg must be stay !!!
    Then put it in your selfmade folder (named: programs or games) into your SD-Card.
    Only working files with max. 202 blocks or smaller, complete disks are not supported.
    Select these file/s at your mmc64 and have fun :smile:
    CU RectowN
  • Zitat
    Original von xiphias256
    I had exactly the same problem with my C128D. It was caused by contact problems at the expansion port. The PCB of the MMC64 is a little bit thinner than PCBs of other cartridges.
    Only when I have a cartridge connected to the MMC64, the hardware runs stable. The additional weight of the cartridge lasting on the MMC64 and pushing it down a bit makes the electric connection between the MMC64 and the expansion port much more stable, resulting in a much better behavior.
    CU
    Kratznagel
  • Oki, thanks for the tip! I will try this.
    But how about games that uses a lot of smale files, will the game be able to load other files it uses, as long as it is under 202 blocks??
  • Zitat
    Not yet. :( Someone has to patch these games individualy for the MMC64.
    CU
    Kratznagel
