Hi, i am a new user of this forum, i discovered few days ago the EasyFlash crt games, i have one question:Is possible an EasyFlash of Dragon's Lair 1 & 2?
Hallo Besucher, der Thread wurde 7k mal aufgerufen und enthält 25 Antworten
letzter Beitrag von alx am
- maxstar1971
- Erledigt
With Disk2Easyflash you can create it on your own.
Here are my results:
Thanks!
I know but there is a gui version of Disk2Easyflash or a little and easy guide to use this little tool?
I'm like to have also a copy of Terramex. How i can do it on easyflash? -
Thanks!
I'm sorry, there is no GUI-Version. A tutorial of disk2easyflash you can find here. By the way, if you use a higher Windows-Version as XP, you have to set the disk2easyflash.exe to compatibility mode xp. -
It hardly can be easier than this "disk2easyflash.exe -c terramax.d64 easyflash.crt".
I tried and it say unable to open terramex.d64
i have all files in c: -
For this example the disk file called "terramax.d64" needs to be in the same location as "disk2easyflash.exe" and you must be in that directory.
Ignore the quotation marks (""). It is just to explain it... -
Works. i renamed "Terramex.d64" in "1.d64" and work!
It will load also the levels in multiload? and how can create for multiple disks? is possible create a crt for example of Elvira II?
Terramex, the Papillions Crack is already an one-filed prg. There is no need to do a Disk2EasyFlash conversion. You can put it in an EF compilation CRT, with Dracos Cartridge Maker or ndef.
Zitatis possible create a crt for example of Elvira II?
Haven't tried, but i don't think so.
Elvira II, but it's 8 disks anyway.
Which is the sintax to create a crt with multiple disks? like creatures II for example (2 disks) with 2diskstoEasyflash?
You have to combine all files into a single image. In that case you have to switch to a D71-Image, it is big enough.
End remember, lots of games/disk are not compatible with disk2easyflash - try and error. -
You can't create CRTs out of Multidisk games with Disk2EasyFlash. This needs to be properly patched for EF. For Creatures II, there is already a CRT version which works with EF too.
http://www.lemon64.com/forum/v…95092ba06f99e06f2cea9fc2d
Creatures I & Mayhem in Monsterland
You can't Multidisk games this with Disk2EasyFlash. This needs to be properly patched for EF. For Creatures II, there is already a CRT version which works with EF too.
Thanks, i downloaded today the game!
You can find more (the ones which worked) Disk2EasyFlash conversions here.
Thanks! i downloaded all Fertige Images today in this forum
DL1.zip
DL2.zipLevel 2 does not work on both parts!
Do not expect too much from disk2easyflash. The success rate of multipart-games is less than 5%.
Afaik multipart releases must fulfill a bunch of restrictions such as filebased loading systemto work with D2EF, no fancy trackloading stuff. Anything which only uses KERNAL disk operations and is no larger than 2 disk sides (you can fool Disk2EF with .D71 images by renaming index to .D64) has good chances of working.
