Hi,
I finally got to assembling my FE3 version 0.9! Yeah!
When I boot the VIC 20 I get the normal VIC 20 screen. When I insert a FAT16 formatted SD card, the green LED pulses. Next I try to LOAD"$",8, but there is a device not found error. The same happens when I use device numbers 9, 10 and 11.
Strange, because when I connect a SD2IEC device (http://www.sd2iec.co.uk/id14.html), I can read the contents of the SD card.
What can be wrong? I checked the connections to the serial connector twice with a multimeter. I also experimented with the jumpers, but maybe I do something wrong with them. What would the correct jumper settings be? I also tried changing the 3.3V and 5V CLPD jumper...
The ICs have no label sticker on them,so I do not know hat version is on them...
Cheers,
Johan
