cc65 Maintainer hört auf
Es gibt 8 Antworten in diesem Thema, welches 1.888 mal aufgerufen wurde. Der letzte Beitrag (19. März 2013 um 19:30) ist von polluks.
  • Nach über 13 Jahren Entwicklungszeit hört Ullrich von Bassewitz auf:
    After some mulling I have decided to terminate my work on cc65. I'm sorry if
    this causes inconveniences.
    Provided that it is not too much hassle for me, I will keep up the cc65
    resources for reference. This means that:
    * ... the web page will stay up but I will attach a note that no further
    development will happen.
    * ... the mailing list will stay active as long as there is some interest
    and people would like to discuss cc65 issues here.
    * ... the Wiki will stay up for now, but may close some time in the future,
    since it needs regular maintenance for security reasons.
    * ... the subversion repository is currently undecided. It's not much work
    to keep it up, I will probably keep it for now, but it may close done
    at some point in the future. Don't know about the developer accounts
    however.
    * ... the FTP server is still active, but I will terminate the cron job
    that builds the snapshot.
    If someone wants to take over, please step forward. Beware: I've seen more
    than one time people taking over a project and then fail once they were
    exhausted from exchanging all the copyright messages:-) If someone takes over,
    I would of course be happy if this won't happen with cc65. If someone wants to
    take over development, I can offer to host some or all of the resources. As
    said above, the only thing that is some work from time to time is the Wiki.
    C128DCR mit Comet64
    Apple IIgs (defekt)
    Acorn Electron
    Oric Atmos (defekt)
    VC-20 mit UltiMem
  • Schade, nutzen viele C für den Cevi? Selbst auf dem Amiga wäre ich nie auf die Idee gekommen C zu nutzen, außer für OS-Tools vielleicht, also für alles was nicht zeitkritisch ist.
    Gerade Assembler und Linker aus dem cc65 Paket werden - so wie ich das mitbekommen habe - gerne bei größeren Projekten eingesetzt.
    sauhund wird sicher wieder bezüglich des Linkers ins Schwärmen geraten, sobald er den Thread entdeckt hat =)
  • Schade,schade...hab das gerne benutzt, auch wenn ich immer noch finde, dass die floats da zwingend rein gehören...
  • Das ist ausgesprochen schade. Über die Beweggründe kann man nur spekulieren, aber es werden vermutlich schwerwiegenden Gründe sein, die einen einen solchen Schritt gehen lassen.
    Ich hoffe, es findet sich ein geeigneter Nachfolger.
  • Alle Easyflash tools (Easyprog, menu) haben zumindest ein Framework in C.
    Deshalb sind die ja so Benutzerfreundlich :wink:
  • Na da scheint ja dann wirklich Bedarf zu bestehen.
  • schade, ja.... aber machdem er schon die libraries abgegeben hatte leider absehbar.
    es wird sich aber sicher ein maintainer finden... eine ganze reihe anderer projekte hängen mehr oder weniger davon ab (contiki, chameleon, krills loader wären die die mir spontan einfallen) so das es sich kaum vermeiden lassen wird auch den compiler/assembler weiter zu pflegen :)
  • Das Gefühl ist ähnlich dem als hätte die Freundin Schluss gemacht ;(
    Das Kind muss sich jetzt "in der harten Welt der Compiler" allein behaupten ...
    C128DCR mit Comet64
    Apple IIgs (defekt)
    Acorn Electron
    Oric Atmos (defekt)
    VC-20 mit UltiMem
