Geos 2.5 bootfähig auf SD2IEC/D81 über Geomakeboot
Es gibt 119 Antworten in diesem Thema, welches 54.026 mal aufgerufen wurde. Der letzte Beitrag (24. Juli 2023 um 11:05) ist von wweicht.
  • Ja, Man kann die SeriNR. an das Vorhandene Geos anpassen, dafür gibts genug Programme..............
    Oder man nimmt einfach Applikationen, aus den die SeriealNR. Entfernt wurde................
    Ich möchte noch Bemerken, ich war nicht derjenige, der die SerNR. Entfernt hat,
    ich hab das auch nur im Netz Gefunden. Im Prinzip funktionieren die Appl.,
    ich weiß jetzt allerdings nicht inwieweit die schon Gepatcht sind.............
    Bitteschön:
  • Hello, Werner. Could you point me to any info (or disk images) of GEOS V2.01? Was it only for C64 or C128 as well? I'm giving the finishing touches to GEOS Kernal Construction Set (for the C128) and if there were any updates, I'd like to check them out. I may be extending support for GEOS 64 (cartridge based, of course) if there is interest. Thanks!
  • yes, I do have a great interest in an cartridge based version of GEOS.
    Should be able to run in EF3 or KFF
    I guess that you already know about one bootable cartridge version (see attachment) which is 2.1 english.
    of cours this is only the kernal routine and all other stuff still has to be run from real floppy or disk image.
    For my knowlege GEOS 2.5 (German) was the latest release by Berkley. Later versions were 3rd party but you will find all relevant informations in this wiki
    Bitte melde dich an, um diesen Link zu sehen..
  • For my knowlege GEOS 2.5 (German) was the latest release by Berkley.
    No. This was C64 only and by M&T, not Berkely Softworks.
    As so called Function ROM (that's what it is now) it can be run for instance from a cartridge way simpler than EF3 or KFF. But it doesn't need any cart at all if installed internally.
    Awesome. I could implement basically the same options available for the C128, that is: drive type and device number, default input driver, RAM expansion support (REU/GEORAM), Kernal serial number and, of course, nationality :)
    Regarding EF3/KFF, I'll have to check what are the compatibility requirements.
    Agreed. As far as I could see (very briefly), GEOS 2.5 is still Kernal 2.0. My interest in a 2.01 version is to check whether there are changes in the Kernal or in some additional files. Thank you for the attachment and the Wikipedia link.
  • As so called Function ROM (that's what it is now) it can be run for instance from a cartridge way simpler than EF3 or KFF. But it doesn't need any cart at all if installed internally.
    Yes. Just to clarify, what I've already done is a tool to create a 32K function ROM for the C128, which doesn't require any additional hardware, as it fits on the empty U36 socket of the C128 (or even some 17xx REU models). For the C64, that is not possible, so you would either need a cartridge to hold the EPROM or perhaps the empty socket in the mentioned REU models. Excuse me for writing in English.
  • For the C64, that is not possible, so you would either need a cartridge to hold the EPROM or perhaps the empty socket in the mentioned REU models.
    Ah yes, now I see it's a thread about GEOS64. Seeing your name here led me to the suggestion it's still about GEOS128. Sorry for that.
    That's fine, really.
    This is german GEOS and can be found on F64-Wolke (Software\GEOS\System) or here: Bitte melde dich an, um diesen Link zu sehen.
    Bye
    Werner
  • of GEOS V2.01? Was it only for C64 or C128 as well?
    Short note :wink: :
    This (Geos 2.01) is Geos 64 and Geos 128. There are no official notes about this "update". The only new thing I know: The german program geoMerge on this Geos V2.01 need no installation on geos serial number. I don't know this was also for US Geos available.
    And Geos V2.5 only exist for german Geos and only for C64. It's Geos 64 2.01 and some more programs (Topdesk, Wordcutter (Silbentrenner)), little tools, printer - and input drivers. The additional programs was distributed by german Geos User Club (GUC) befor Geos 2.5 was distributed.
    Werner
  • so is the followin timeline correct
    GEOS 2.0 64 and 128 multilingual
    GEOS 2.01 64 and 128 only German
    GEOS 2.1 does not exist, obviously a misspelling of 2.01
    GEOS 2.5 only 64 German, no Kernal update only some cosmetic changes and pre-released tools
  • GEOS 2.01 64 and 128 only German
    I'm not sure this is german only ...
    Correct.
    There are no cosmetic changes. There is only more software (from german programmers) as in Geos V2.0/2.01.
    Bye
    Werner
  • Danke für den link. Leider nicht die D81 Version dabei..
    Edit: doch dabei, bin echt blind..8)
  • nicht die D81 Version dabei.
    Ja, das ist nicht so einfach. Du hast ja nicht mal geschrieben, wo das Video auf YT zu finden ist oder wer dessen Autor ist. Vielleicht kann dann jemand anders was dazu sagen.
    Das Bild sieht nach US Geos aus (englischer DESKTOP) . Außerdem ist es eine spezielle Konfiguration (TURBOBOOT, uIecSwitch). Frag doch einfach mal den Ersteller des Videos, der muß es ja eigentlich wissen ....
    Werner
  • Ja, das ist nicht so einfach. Du hast ja nicht mal geschrieben, wo das Video auf YT zu finden ist oder wer dessen Autor ist. Vielleicht kann dann jemand anders was dazu sagen.
    Der Borg ist ein polnischer youtuber, der mal live ein Ultimate 64 getestet hat. Dabei zeigt er diese .D81 GEOS- Version. Natürlich wäre wir die Deutsche Version lieber.. :D
  • Habe auf YT eine .D81- GEOS Version gesehen, wo alles fertig eingerichtet war. Wo findet man diese Version?
    Wie es der Zufall will, habe ich gar nicht so lange her hinter einer Datei "turboboot" recherchiert, die sich auf einer niederländischen Geos-Diskette befindet. Es hat sich herausgestellt, dass ein bestimmter Crack, den ich nicht besitze, jene Datei auf der Bootdiskette speichert und damit zumindest auf Commodore-Floppies funktioniert.
    Das ist natürlich nicht auf ein niederländisches Geos beschränkt, da habe ich das nur vorgefunden.
    Edit: Sucht man im Internet nach "geos crack turboboot" - findet man Bitte melde dich an, um diesen Link zu sehen. und da Geo Snap, welches Kopien bootbar machen soll und "turboboot" hinterlässt - wie behauptet.
    Keine fertige Diskette/D81, aber kann man damit ja selbst herstellen. Geht auch mit GeoMakeBoot.
  • Schade, dass es keine (De) GEOS Easyflash Version gibt. Es wäre doch sicherlich sehr schnell.. :thumbup:
    Habe früher selbst GEOS 1.2 in der Schulzeit benutzt, und war damals sehr begeistert. Nun wollte ich nach 30 Jahren mal wieder GEOS abfeuern,
    und trotz Easyflash und Ultimate 64 ist wirklich sehr viel Müll im Umlauf.. Patches, englische Versionen.. Ich blicke da echt nicht durch..?(
