Hello, Guest the thread was called1.8k times and contains 7 replays
last post from sauhund at the
Neue CBM .prg Studio Version veröffentlicht, aktuell: 3.0.0
  • 2.5.0
    Arthur hat ein Update seiner Entwicklungsumgebung veröffentlicht. Hauptänderung diesmal: Unterstützung der Zielplattformen PET 2001/4000/9000 und VDC mode für den C128er Bildschirmdesigner. Ansonsten die üblichen kleinen Bugfixes:
    Download und Spendenmöglichkeit wie immer hier: http://www.ajordison.co.uk/
    Anmerkung: Diskussionsthread zur Version 2.4.0 war hier: http://www.forum64.de/wbb3/boa…mme-auf-dem-pc-entwerfen/
    Computer:C64, VC20 Monitor:1702, 1084S Floppy:1541, 1541-II Speicher/Datenübertragung:MMC Replay, 1541U-II, Chameleon, C64TPC, sd2iec, EasyFlash, NeoRAM, XA1541, XU1541 Sprachausgabe:Magic Voice, Voice Messenger, HearSay 1000, Adman Speech Maker, VoiceBox AlienGroup, Covox Voice Master Sonst:Robotarm SVI-2000, Kemtec AMS 64, HardSID4u se, SammichSID, SIDstation, SFX Sound Expander, SFX Sound Sampler
    Edited 6 times, last by Stefan67 ().
  • 2.5.1
    Die Version 2.5.1 des CBM prg Studio wurde veröffentlicht, überwiegend Bugfixes
    New features in v2.5.1:
    • Some of the IDE's colours can be changed (background, tab strip, selected and non-selected windows).
    • Menu to control open windows.
    • Warnings if invalid BASIC jump (goto, gosub etc.) destinations are detected.
    • ZPOpt directive added
    Bugs fixed:
    • Added 'missing' colours to VIC 20's screen designer.
    • Default project location not being saved if the target machine was not changed.
    • Assembler not assembling mixed case text directive strings properly.
    • Dark and light gray colours were switched.
    • Opening a project after a project had already been opened would use 'my documents' rather than the project directory.
    • Incbin failed when used screen designer files.
    • No colours were visible when starting the screen designer without loading a previous file.
    • CTRL+Z not scrolling to changed text.
    • * not recognised for current address.
    • local labels not recognised in certain circumstances.
    • Generation/import of prgs > 65k for C128 programs would fail.
    • missing BASIC 7 'RLUM' keyword.
    Edited once, last by Stefan67 ().
  • 2.5.2
    Die Version 2.5.2 des CBM prg Studio wurde veröffentlicht.
    New features in v2.5.2:
    • User defined pre- and post-build events.
    • Improved post-build assembly dump.
    • Detection of zero page instructions which can be optimised.
    • NoLoadAddr directive added.
    • Ditched Windows Setup!
    Bugs fixed:
    • Problem with directives not in the first column.
    • Problem with labels which look like numeric values.
    • Some missing keywords from C128 BASIC.
    • JSR optimisation issues.
    • Using IncBin with sprite data.
    • The way in which lo/hi byte calculations has changed.
  • Die Version 2.7.0 des CBM prg Studio wurde veröffentlicht.
    New features:
    •Debugger:
    ◦Keyboard shortcuts.
    ◦Instruction cycle counter.
    ◦Overlay files.
    ◦VICE Snapshot files (for C64 and VIC 20 only).
    ◦Better execution control, e.g. step over, into etc.
    ◦Change SP and SR registers.
    ◦Memory viewer.
    ◦Much better performance.
    ◦Updated tutorial.
    •Character editor:
    ◦Edited characters indicator.
    ◦Copy groups of characters.
    ◦Scroll the scratchpad.
    •BASIC:
    ◦Batch mode added.
    ◦Constants can be defined/redefined in code, and use hex values.
    ◦Auto line numbering inproved.
    Bugs fixed:
    •'£' was in invalid BASIC character.
    •$(nn),y was not being assembled properly, whereas ($nn),y was.
    •Casted offsets (offsets which are based on other offsets) were broken.
    •Problems renumbering BASIC programs with ON..GOTO/GOSUB with spaces in the line number list.
    •PC relative offsets (e.g. bvc *-2) fixed.
    •'Align' directive not working.
    •Load/save in character editor.
    •Multicolour issues with the screen/character/sprite editors.
    •Including sprite files (IncBin) into assembly source only generated 63 bytes.
  • Die Version 3.0.0 des CBM prg Studio wurde veröffentlicht.
    New features:
    ◦65816 assembler/debugger.
    ◦Partial support for the VICE debugger.
    ◦Bitmap import/export for character editor.
    ◦Binary file import to Assembly source.
    ◦Line and rectangle drawing tools for the screen designer.
    ◦TASM support added to Source Converter tool.
    Bugs fixed:
    •Assembler:
    ◦Using arithmetic with cheap labels would fail.
    ◦Slow incbin performance for large binary files.
    ◦Wrong SYScall generation for C128 projects.
    ◦incbin with screen data imported all screens.
    ◦Assembling past the end of memory not detected properly.
    ◦Invalid branch not detected properly.
    ◦Arithmetic on WORDs not carried out.
    ◦Multiple characters in single quotes in BYTE sequences not assembled properly.
    ◦GenerateTo only created .prg files.
    ◦Save File As... would only save .bas files.
    ◦Comment tool would not comment out already commented code.
    ◦Incbin reporting 'file too large' error by mistake.
    •Screen Designer:
    ◦Binary file export
    ◦Colour selection for C16 projects didn't work.
    ◦Wrong screen size saving C128 screens.
    ◦Character set selection corrected.
    •General:
    ◦Some code reformatting issues.
