Hi
Sorry i ment Easyflash 1.5
Es gibt 1.643 Antworten in diesem Thema, welches 552.269 mal aufgerufen wurde. Der letzte Beitrag (
Hi
hi, I saw that the Metal Warrior trilogy for Easyflash was published on CSDb. Do you think it is possible to create an Easyflash crt with disk2easyflash or another tool for each of the four games?
No need to .. because each of the four Metal Warrior games exists already as "non easyflash" CRT file - I got mine from the "Metal Warrior Quadrilogy Edition".
greetings,
A.
Hello from Portugal, im new here
For me the C64 its the Holly Grail of retro computers i had one with 8 years and it change my world. I just love playing old games but i dont understand a lot about conversions. just discover now the CRT, easyflash files and man, it runs a lot better the games... I all ready download a big list from here but i could not find some games the brings me back a lot of memories, im going to leave a list here if someone can do something about this games this is the place. Thanks for the add in this forum. It's awesome. Stay safe and right now play C64 ![]()
The games are (if you can add with trainers better hihihi some games are just impossibles):
Cobra (ocean)
Operation Wolf
Operation Thunderbolt
Renegade
Target Renegade
Renegade III
Mag Max
Terra Cresta
Druid
Druid II
1943
1942
Cabal
Barbarian 1 and 2
Afterburnner
Outrun
Back to the Futere 1,2 and 3
Batman the Caped Crusader Both games (A bird in the hand and A fete worse)
Beach Head 1 and 2
Bionic commando
BMX simulator 1 and 2
Bomb Jack 1 and 2
Bruce Lee
Buggy Boy
Cauldron 1 and 2
Chase HQ 1
Commando
Cybernoid 1 and 2
Double Dragon 1,2 and 3
Dragon Ninja
Enduro Racer
Express Raider
Fist +
Fist II
Green Beret
Gunship
Hostages
Hyper Sports
Hysteria
IK+
Ikari 1,2 and 3
Impossible mission 1 and 2
Jaws
Karate Champ
Kick Off 1and 2
Kung Fu Master
Match Day 1 and 2
Microprose Soccer part 1 and 2
Narc
Narco Police
Navy Moves
Navy Seals
Paperboy
PitStop 1 and 2
Ploe Position 1 and 2
Power Drift
Predator 1
Rambo first blood II and Rambo III
Rastan
Red Heat
Rick Dangerous 1 and 2
Robocop 1,2 and 3
R-Type
Rygar
Saboteur 1 and 2
Savage
Shinobi
Shadow Dancer
Shadow Warriors
Space Harrirer 1 and 2
Speed Ball 1 and 2
Super Hang On
SWIV
The Great Escape
The Ninja Warriors
The Vindicator
The Way of the Exploding Fist
Thunderblade
Thundercats
Tiger Road
Turbo Esprit
Typhoon
Vigilante
Wings of fury
Yie Ar Kung-Fu 1 and 2
Zorro
Zaxxon
X-out
Sorry for the big list... but if i can get half of this it would be AWESOME... THANKS ![]()
Alles anzeigenHi
I wonder if anyone can help with this issue i have regarding "Armalyte"
i have installed Armalyte.crt on a Easyflash 2 cartridge as a single game but its crashes sometimes during gameplay and at the highscore table
this does not occur in Vice and i have tested the Easyflash 2 cartridge with a different Game and no issues
I guessing this has something to do with the "disk2easyflash" program..
Has anyone else seen this issue
Grant
Someone from Italy also just contacted me for the same reason. I will look into this when I have time. Alternatively Stephan Scheuer or The Joker might have interest or time to make a version.
Armalyte ef-version is just ready programmed and can be found in the "Easyflash Games - Echte Anpassungen" thread.![]()
Hi
The version of Armalyte that can be found in the Easyflash section appears to crash after the High Score Table...
i suspect that the converted program is trying to write to the disk to save highscores ???
Grant
Yes, you are right. the game has a bug in the save routine. It's a really stupidbug I made there. I forgot to change the ef-bank value in the source code. Instead of saving in bank $18, the code has the
old value bank $14 for savine. As a result, the low bank, $10, the low bank $11 and the low bank $12 are deleted after write the high scores in the easyflash.
Thanks for the bug report. a fixed game is uploadet.
Hi
Thanks for you reply..
i am glad it can be solved !
will you attach the new crt file in this post ?
Grant
All Easyflash games that were not created with disk2easyflash can be found in the topic that .mad. linked. If I make game adaption with disk2easyflash, you can find them here.![]()
Hallo, super Sache die Konvertierungen von *.d64 in *.crt !!!
Besteht die Möglichkeit auch Karateka von Broderbund zu konvertieren?
Wäre ne super Sache.
Habe heute The Train - Esape to Normandie.crt ausprobiert.
CapFuture1975 war so liebenswürdig mir den Link zur Datei zu schicken.
es kommt das Introbild mit Musik. Dann kommt der Bahnhof und ich kann,
die ersten Herren am Fenster erschießen, einen Level aussuchen und den Rest der
Herren vom Fenster entfernen ![]()
Wenn dann climb aboard kommt, schaltet der Bildschirm um und es kommt
Müll auf den Bildschirm.
Ich habe es mit Easyflash 1 und mit Easyflash 3 ausprobiert.
schade.
Komisch, bei mir läuft das Spiel problemlos, vom Kung Fu Flash als auch vom Easyflash3.
Wurde das mit disk2easyflash erstellt?
Ich könnte das sonst mal richtig an das Easyflash anpassen.![]()
Ja, genau, ist eine Disk2easyflash Version. Ein echtes Easyflash-Release wäre der Hammer!
Ich habe die verlinkte CRT von dir genommen. Werde morgen aber nochmal
testen, da der PLA sockel böse Schwierigkeiten machte und ich ihn getauscht
habe. Nicht das da das Problem lag. Ist mir grade eingefallen. Habe nach dem Umbau
nicht nochmal getestet.
Habe zuhause nochmal die CRT in Vice laufen lassen. Funktioniert tadellos.
Ist der Cevi dann.
Das wäre obercool von dem spiel ein Easyflash Release zu machen.
Freue mich ![]()
Ich liebe dieses Spiel.
Alles anzeigenIch habe die verlinkte CRT von dir genommen. Werde morgen aber nochmal
Freue mich
Ich habe eben die Datei hier aus dem Forum extra nochmal heruntergeladen und auf dem Kung Fu Flash getestet, läuft einwandfrei, ich konnte auf den Zug klettern.
Ich hatte oben nochmal editiert. Die CRT läuft auch auf Vice.
Ich habe hinterher ja den Sockel der Pla getauscht, weil der böse Kontaktprobleme
hatte. Aber eben nicht nochmal The train eingelegt. Geht morgen los
Ja, teste das morgen mal, kann sein, dass die PLA Probleme machte.
