Just like a promise, new Disk2easyflash collection v3.0 with all games posted here has been uploaded to the server at this day.
Probably tommorow it will be available for download
I will keep you informed.
Hallo Besucher, der Thread wurde 436k mal aufgerufen und enthält 1603 Antworten
letzter Beitrag von CapFuture1975 am
Disk2EasyFlash - Fertige Images
- Ebster
- Erledigt
I have new Disk2EasyFlash Games.
X-Men and Dr. Dooms Revenge
Many thanks to all involved for their efforts!
Finally, you can download latest version of Disk2easyflash collection v3.0 from 01-10-2017. from (un)official Forum 64 server F64-Wolke containing ALL working disk-games posted in this thread:
Go to Software/C64/Easyflash to find collection.
It has 60 MB.What we have here?
1. 392 disk-games in CRT format converted with disk2easyflash program in separate directory
2. 392 disk-games in CRT-XBANK format converted with disk2easyflash program in separate directory
3. 13 games in CRT format (Ocean Type 1 loader) in separate directory
4. Very comprehensive data-sheet in Excel format with all 405 disk-games - besides game name, here you have infos about game type, publisher, year, language, CRT size, CRT-XBANK size, joystick, trainer, level-skip, crack, Lemon64 votes, Lemon64 rating and info if game has "proper" Easyflash release (95% don't have )I should also mention that non-english games are divided in their own directories (overall 32 games out of 392, and 25 of them are in german language).
Yes, Santa came early this year
it is finished.
my first real easyflash release.dr.dooms revenge
there will be more to follow.
greets: Stephan
Schöne Sache, hoffe noch auf ein paar Disketten Monster Klassiker.
Congratulations, Stephan!
Keep them coming
These days I will post in this thread list of ALL disk-games available on C64.
For digging the gold there, and also converting to EF format -
Wow, super was es da alles gibt. Bei manchen Spielen ergibt das wirklich ordentlich Sinn!
Geht das mit Lotus Challenge zufällig auch? -
All right, guys, just like a promise, in this post you have list of ALL disk-games existing on C64
Unfortunately, Gamebase 64 in his "Advance Search mode" doesn't offer to select disk-games, so I need to do manually!
Yes, that means I went manually through all 25.000 files (!) on Gamebase64 website before one year when v14 (September 2015.) was actual, clicking on game-links there.
Then it came actual v15 (September 2016.) with 25.700 files, so I did it all once more (!)!
Of course, a lot can be seen from game names, and even more from thumbnailed pictures of the games to evaluate if game is a disc-game.
For sure I managed to find at least 99% of existing disc-games in Gamebase 64.
I only didn't put on the list Puzzle page games from Loadstar.
There are few dozens of them, and they are small disc games (1D).
Nobody will miss them on the list.I posted in few threads on lemon64.com preliminary list of them before 45 days (version 1), but this version 2 is improved, more accurate and basically final.
To summarize - in Excel list in this post, you can see that C64 has:
- 1.817 small disc games (1D)
- 355 medium sized disc games (2D)
- 155 big sized disc games (3D+)Amazing numbers!
It's also interesting approx. 30% of them are not cracked yet (!), so this will be excellent source for C64 active groups.
Enthusi, spread the word about this list.The Joker, Stephan, this list is also for you, of course
Please, make D2EF releases mainly of good 2D+ games (second & third sheet in Excel sheet), because Easyflash is BORN for playing big-disk games!
Of course, all C64 users will also see a lot of disk-games they never heard before, so let's dig this gold out!
Labyrinth from Activision/Lucasfilm
someone asked for it, here is it.
i have not complete test the game.
if any error occur, please send me a
winvice snapshot or an explanation ofthe error
have fun with it
Greets: Stephan
Hi There, I tested this and it has a bug you get trapped in the Brick Hallway & cannot continue. I have attached the winvice snapshot just before. Thankssave6.rar
Seems I'm stuck too... I can return to Alph and Ralph, but this always brings me back to the Brick Hallway.
According to this walthrough it seems you miss the log that will be needed in the end. You might have to return to the magic wall. Bug how?
Is this a bug in the game, or something we didn't figure out? -
Here is Kikstart II The Construction Set. This version is different to the one on CSDB as it also allows loading/saving to disk as well as EasyFlash.
If anyone wants without intro (loosing option to reset highscores and view docs) then let me know.
Also die Cartridge-Version von Oil Imperium hat noch immer eine Code-Afrage versteckt.
Wenn man das Spiel startet, dann ist es egal, welchen Code man eingibt. Als ich die Abbau-Rechte im dritten Gebiet kaufen wollte ist aber plötzlich eine Code-Abrage gekommen, bei der der Code auch stimmen musste. Zum Glück habe ich ihn in diesem Thread hier gefunden.
Vielleicht sollte man das dem Zip beilegen, sofern man das Spiel nicht entsprechend patcht. -
Vielleicht sollte man das dem Zip beilegen, sofern man das Spiel nicht entsprechend patcht.Die Codeabfrage hatte ich in der Scpu-Ramcard Version vollständig entfernt,
ich werde mal nachschauen, wie ich das gemacht habe. soweit mir bekannt ist, ist der Code
gegen veränderung geschützt.Gruß: Stephan
Die Hard from Activision
my second real easyflash game
tested from start to finish.
have fun with it
greets: stephan
Thanks for the report.
i have look youtube videos from this game.
Du you open all doors in the brick-level ?Ich wiil this weekend search fo a solution of this problem.
greets: stephan
Thanks for the report.i have look youtube videos from this game.
Ok I checked again. Doesn't have to do with the log.
On the disk version I get from the Magic Wall into the Brick Hallway, then Alph and Ralph and then the Stone Corridor.
On the cartridge version I get from the Magic Wall to Alph and Ralph, then Brick Hallway, and then back to Alph and Ralph.
And I did exactly the same in both turns.So let's wait what Klaus' search will show...
the tapeversion of labyrinth i use to make the easyflash, has file dubletten. same name, different content.
crap!
i will try to fix this at the weekend.
greets: stephan
In the game Labyrinth every game is different, when you get to Alph and Ralph first ask them and they will tell you what to do next, for instance to open all doors in the Brick Hallway before you can continue... same with the wise man, different games, different solutions...
greetings,
A.
