Disk2EasyFlash - Fertige Images
Es gibt 1.643 Antworten in diesem Thema, welches 552.279 mal aufgerufen wurde. Der letzte Beitrag (30. Oktober 2025 um 14:48) ist von Stephan Scheuer.
  • Hello
    Has anyone tried to convert "time soldiers" using disk2easyflash ?
    i tried myself but the game crashes after the start menu...
    I just made a native EasyFlash version from the original US GOLD/Novaload tape. Checking now with the crew if we want to put all the bells a whistles on it too (intro, dox, trainers + HS saver etc).
    Wow, thanks for your work! :D
  • Hey All
    Any chance of an Easyflash Version of Metal Warrior Ultra????
    Buy it. It comes with an EasyFlash version.
  • I found another game that work with the last version of Disk2easyflash:
    Teenage Mutant Hero Turtles - The Coin-op (1991).
    Disable fastloader on trainer menu (in this case select Y).
  • At First it was not loading with Vice 3.5.
    Later I have found out Vice 2.4 would run it.
    However it still needs to create characters,
    if not you still need to insert a savegame disk with the characters you created, or the disk that contains original pr-generated characters.
    Otherwise it runs in fast speed almost like the DOS verison.
    Are you keeping up with the Commodore? 'cause the Commodore is keeping up with you!
  • I could not figured this .7z.001 and .7z.002 thing out. I have tried many combos. Any help here?
    Thanks1
  • Is it the disk2easyflash version? If so, i will fix the bug.:)
    I took a quick look at the code and i found out that all levels are affected by it.
    If you know anything about 6502-assembler, take a look at the contents of the code window. From this you can see why the game is not working.
  • A tip to facilitate the D2EF adaptation =)
    Disk2EasyFlash V0.9.3
    - Added a helper routine to $DF02 (trap installer). It can be called to update the Kernal vectors used by D2EF in case of a need.
  • Thanks for the hint.:) Sorry but at the moment I have not the slightest idea above the trap installer.:gruebel
    Can you do that. I'll take a look at the code to see how to do that.:)
  • You are welcome. =) Actually its easy, just call $DF02 at the right point.
  • Terminator II - Judgment Day (1991)
    Test Drive II (1989)
    Tiger Road (1988)
    Trolls (1993)
    Turrican 3 (2004)
    Trolls is buggy. Level 2, instead of Fableland, is Candy World (i.e. level 1 again) with a different color scheme, whereas level 3 (Cherry Soda Sea) is full of corrupt graphics.
  • Beitrag von Roger Frames (29. September 2021 um 22:31)
    Dieser Beitrag wurde von marty gelöscht (30. September 2021 um 06:48).
  • Twinworld (1990)
    Untouchables (1989)
    Valentino (1988)
    Vendetta (1990)
    Viz (1991)
    I've tried Untouchables but it doesn't work well, sometimes the game loads but with glitched graphics on level 1 but most of the time doesn't work to me (Tested both on VICE and real C64 with 1541-Ultimate II).
    I saw that this .crt was made using D2EF 0.9.3-R1, so i did the same but using 0.9.3-R2.
    Now the game works flawlessly! :thumbsup:
    N.B. : Remember to disable fastload :)
  • Thx
  • Beitrag von Szabcsik (10. Oktober 2021 um 18:33)
    Dieser Beitrag wurde von Ebster aus folgendem Grund gelöscht: Doppelpost (12. Oktober 2021 um 22:18).
