Disk2EasyFlash - Fertige Images
Es gibt 1.643 Antworten in diesem Thema, welches 552.240 mal aufgerufen wurde. Der letzte Beitrag (30. Oktober 2025 um 14:48) ist von Stephan Scheuer.
  • Metallic,
    Thank you for Disk2Easyflash adaptation of Ghouls'n'Ghosts.
    I hope you will do them more.
    You're welcome. I'll try to do some more when I have enough free time. Actually, I would be more enthusiastic if Disk2EasyFlash makes the adaptation a little more easier. With Disk2EasyFlash, loading from the current file cannot be done one byte a time. This makes it difficult to adapt cracks that have on-the-fly depacker. On-the-fly depackers are also being widely used in the existing cracks. I wish alx had made an update to Disk2EasyFlash for this matter.
  • I've tried it once, but it's not as easy at it seems. D2EF is open source (at least it should be, it's been a while) - feel free to improve it.
  • Alex, The Joker updated Disk2Easyflash program before few years allowing me to convert d81 files.
    Master also wrote last year in this thread he can improve Disk2Easyflash to have more compatibility, but he doesn't have enough time then.
    Maybe three of you can join efforts to bring new version of Disk2Easyflash?
    I really squeeze all the juice from present version 0.9.2fix, managing to find more than 400 disk games compatible with D2EF program in last 4 years.
    To find them, I tested approximately 15 times more..
    Now it's easier to test them - no need for flashing D2EF files to EF3 cartridge anymore, Kung Fu Flash cartridge doing this 50 times faster, it flashes directly from SD card, and compatibility is 100% with D2EF and EF releases :)
  • Gibt es eigentlich irgendwo (Wolke?) eine Sammelstelle wo alle diese Anpassungen,
    on nun "Disk2Easyflash" oder "Echte Anpassungen" gesammelt werden?
    Das Ganze ist zwar mittlerweile so umfangreich das ich nie alles testen könnte, aber
    "Haben war schon immer besser als Brauchen", und SD's sind recht geräumig.
    Futter fürs Kung Fu Flash!
    Mfg Jood
  • Disk2EasyFlash V0.9.3
    - Based on the version 0.9.2 released by The Joker .
    - Added "get byte from file" functionality. It works by calling $FFCF (CHRIN) or $FFE4 (GETIN) routines.
    - Added a helper routine to $DF02 (trap installer). It can be called to update the Kernal vectors used by D2EF in case of a need.
    - Changed error handling of LOAD process a bit. If the file couldn't be found in the D2EF directory, it signals "FILE NOT FOUND" error without redirecting the process to real disk drive.
    - PC-side source codes have not changed much, only the new object code for C64 has been inserted into "binaries.c" file.
    - Assembly source code that belongs to C64 has been added to the release (d2ef.asm).
    - Multi open-file access is not supported.
    - Reading the DOS messages over the command channel is not supported.
    Some notes for the Disk2EasyFlash adaptations
    What I wanted to do by adding the get-byte function was to make it easier to adapt games that include on-the-fly depackers. Most of them are using $EE13 routine to get bytes from a file. Replace it with $FFCF or $FFE4. The file in the process must also has been opened in a standard way beforehand.
    Hammerfist
    When I wanted to adapt Hammerfist to Disk2EasyFlash back in the days, I gave up seeing that most of the cracks were using on-the-fly depackers. Now, I've selected Ikari and Talent release and the adaptation work didn't take too long thanks to the get-byte function. $DF02 routine also made it pretty easy. There wasn't a level skipper, I've added one. Press CBM key to level skip (usable at the first level only). Enjoy.
  • Ich suche Beach Head II als CRT für Easyflash.
    Gibt es das schon?
    Die Königin sie zittert.
    dann hab ich Blut gewittert.
  • Tatsächlich scheint hier eine gute Umsetzung von der Disk zu fehlen.. meiner Erinnerung nach gibt es nur einen Tape Crack als EF.
  • Ebster
    Habe gestern eine 1 Disk Version von Beach Head II rausgekramt. Die hat aber nen
    Fastloader und ich weiß nicht ob es ein Problem für die Umsetzung ist.
    Hast Du einen Link für die Tapeumsetzung. Würde ich mir gerne mal anschauen.
  • Fepo , in der Wolke gibt es ein Archiv von CommFor . Es müsste das Easyflash Nirvana sein. Wenn es existiert, nach meiner Erinnerung ja, dann ist es da drin. Oder hier im thread ;-). Am Remember Diskimage hatte ich mich seiner Zeit selbst versucht, das wollte leider nicht..
  • Habe ich gerade eben gemacht. Beach Head II Tape-Rip. Die Anweisung zum starten das Spiels, steht im Directory.
    Einen on-the-fly decrunacher in D2EF einzubauen, wäre überhaut kein Problem. Ich nutze hierbei mehrere von mir
    angepasste Versionen, einmal die vom LevelCrusher v1.0, dann vom Exomizer V2.xx oder auch vom Exomizer v3.xx.
