Disk2EasyFlash - Fertige Images
Es gibt 1.643 Antworten in diesem Thema, welches 552.230 mal aufgerufen wurde. Der letzte Beitrag (30. Oktober 2025 um 14:48) ist von Stephan Scheuer.
  • hi, I saw that the Metal Warrior trilogy for Easyflash was published on CSDb. Do you think it is possible to create an Easyflash crt with disk2easyflash or another tool for each of the four games?
    No need to .. because each of the four Metal Warrior games exists already as "non easyflash" CRT file - I got mine from the "Metal Warrior Quadrilogy Edition".
    greetings,
    A.
  • Hello from Portugal, im new here :) For me the C64 its the Holly Grail of retro computers i had one with 8 years and it change my world. I just love playing old games but i dont understand a lot about conversions. just discover now the CRT, easyflash files and man, it runs a lot better the games... I all ready download a big list from here but i could not find some games the brings me back a lot of memories, im going to leave a list here if someone can do something about this games this is the place. Thanks for the add in this forum. It's awesome. Stay safe and right now play C64 :)
    The games are (if you can add with trainers better hihihi some games are just impossibles):
    Cobra (ocean)
    Operation Wolf
    Operation Thunderbolt
    Renegade
    Target Renegade
    Renegade III
    Mag Max
    Terra Cresta
    Druid
    Druid II
    1943
    1942
    Cabal
    Barbarian 1 and 2
    Afterburnner
    Outrun
    Back to the Futere 1,2 and 3
    Batman the Caped Crusader Both games (A bird in the hand and A fete worse)
    Beach Head 1 and 2
    Bionic commando
    BMX simulator 1 and 2
    Bomb Jack 1 and 2
    Bruce Lee
    Buggy Boy
    Cauldron 1 and 2
    Chase HQ 1
    Commando
    Cybernoid 1 and 2
    Double Dragon 1,2 and 3
    Dragon Ninja
    Enduro Racer
    Express Raider
    Fist +
    Fist II
    Green Beret
    Gunship
    Hostages
    Hyper Sports
    Hysteria
    IK+
    Ikari 1,2 and 3
    Impossible mission 1 and 2
    Jaws
    Karate Champ
    Kick Off 1and 2
    Kung Fu Master
    Match Day 1 and 2
    Microprose Soccer part 1 and 2
    Narc
    Narco Police
    Navy Moves
    Navy Seals
    Paperboy
    PitStop 1 and 2
    Ploe Position 1 and 2
    Power Drift
    Predator 1
    Rambo first blood II and Rambo III
    Rastan
    Red Heat
    Rick Dangerous 1 and 2
    Robocop 1,2 and 3
    R-Type
    Rygar
    Saboteur 1 and 2
    Savage
    Shinobi
    Shadow Dancer
    Shadow Warriors
    Space Harrirer 1 and 2
    Speed Ball 1 and 2
    Super Hang On
    SWIV
    The Great Escape
    The Ninja Warriors
    The Vindicator
    The Way of the Exploding Fist
    Thunderblade
    Thundercats
    Tiger Road
    Turbo Esprit
    Typhoon
    Vigilante
    Wings of fury
    Yie Ar Kung-Fu 1 and 2
    Zorro
    Zaxxon
    X-out
    Sorry for the big list... but if i can get half of this it would be AWESOME... THANKS :)
  • Someone from Italy also just contacted me for the same reason. I will look into this when I have time. Alternatively Stephan Scheuer or The Joker might have interest or time to make a version.
  • Hi
    The version of Armalyte that can be found in the Easyflash section appears to crash after the High Score Table...
    i suspect that the converted program is trying to write to the disk to save highscores ???
    Grant
  • Yes, you are right. the game has a bug in the save routine. It's a really stupidbug I made there. I forgot to change the ef-bank value in the source code. Instead of saving in bank $18, the code has the
    old value bank $14 for savine. As a result, the low bank, $10, the low bank $11 and the low bank $12 are deleted after write the high scores in the easyflash.
    Thanks for the bug report. a fixed game is uploadet.
  • All Easyflash games that were not created with disk2easyflash can be found in the topic that .mad. linked. If I make game adaption with disk2easyflash, you can find them here.:)
  • Hallo, super Sache die Konvertierungen von *.d64 in *.crt !!!
    Besteht die Möglichkeit auch Karateka von Broderbund zu konvertieren?
    Wäre ne super Sache.
  • Habe heute The Train - Esape to Normandie.crt ausprobiert.
    CapFuture1975 war so liebenswürdig mir den Link zur Datei zu schicken.
    es kommt das Introbild mit Musik. Dann kommt der Bahnhof und ich kann,
    die ersten Herren am Fenster erschießen, einen Level aussuchen und den Rest der
    Herren vom Fenster entfernen :)
    Wenn dann climb aboard kommt, schaltet der Bildschirm um und es kommt
    Müll auf den Bildschirm.
    Ich habe es mit Easyflash 1 und mit Easyflash 3 ausprobiert.
    schade.
    Die Königin sie zittert.
    dann hab ich Blut gewittert.
  • Komisch, bei mir läuft das Spiel problemlos, vom Kung Fu Flash als auch vom Easyflash3.
  • Wurde das mit disk2easyflash erstellt?
    Ich könnte das sonst mal richtig an das Easyflash anpassen.:)
    Ja, genau, ist eine Disk2easyflash Version. Ein echtes Easyflash-Release wäre der Hammer!
  • CapFuture1975
    Ich habe die verlinkte CRT von dir genommen. Werde morgen aber nochmal
    testen, da der PLA sockel böse Schwierigkeiten machte und ich ihn getauscht
    habe. Nicht das da das Problem lag. Ist mir grade eingefallen. Habe nach dem Umbau
    nicht nochmal getestet.
    Habe zuhause nochmal die CRT in Vice laufen lassen. Funktioniert tadellos.
    Ist der Cevi dann.
    Stephan Scheuer
    Das wäre obercool von dem spiel ein Easyflash Release zu machen.
    Freue mich :)
    Ich liebe dieses Spiel.
  • Ich habe eben die Datei hier aus dem Forum extra nochmal heruntergeladen und auf dem Kung Fu Flash getestet, läuft einwandfrei, ich konnte auf den Zug klettern.
  • CapFuture1975
    Ich hatte oben nochmal editiert. Die CRT läuft auch auf Vice.
    Ich habe hinterher ja den Sockel der Pla getauscht, weil der böse Kontaktprobleme
    hatte. Aber eben nicht nochmal The train eingelegt. Geht morgen los
